Question about Minolta EP4000/5000 CS/PRO Copier
5000 code c 0500
  • Minolta Master
  • 1,294 Answers
The C 5XXX code refer to fusing unit abnormal function.
Verify the fusing heater lamp continuity,the thermofuses continuity and the oil roller.5000 - c80853bd-bcea-44bc-8236-cd75d9392f89.jpg
Posted on Apr 25, 2013
Why am i still getting error code 0500 i bought a new fuser unit.
You need to reset the machine, the new fuser does not reset the machine.
May 03, 2014 | Konica Minolta magicolor 1690MF All-In-One...
Trouble shoot konica minolta error code 0500
need to know model number
most konica minolta 0500 codes is fuser related and a tech has to reset it
Aug 22, 2013 | Konica Minolta bizhub Office Equipment &...
What causes Error code 0500
Fusing Unit Heating problem. Meaning that the fuser is not heating up as it should. This unit is located right where the paper exits the machine, behind the left side door that opens. The most common failure that causes the code is the thermal fuse. When the fuse blows it cuts the power to the heater lamp. When the machine does not see the proper temperature within a specific amout of time the C0500 code comes up. Good news is it is a $5 part. Only bad news is you will need a service tech to remove the fusing unit, replace the part, then clear the C0500 code from the copier memory.
Good Luck and Thank You for using Fixya.
Sep 26, 2010 | Minolta EP4000/5000 CS/PRO Copier
Code c 0500
fuser problem to rest this code you need to turn on the machine and open front cover then remove one small cover in the lift side machine you will find small botton black color (trouble) press it
Aug 20, 2010 | Minolta EP4000/5000 CS/PRO Copier
IRC5185i Stopped working. Shows Error code
i looked to see if there was a user fix for this problem but there isn't. It sounds like the driver pcb board could be blown and or the fixing assembly needs replace.
Jun 05, 2010 | Canon imageRUNNER 5000 Copier
Puk code i want
What should I do if my iPhone says error P1246?
Answer:
A PUK code (Pin Unlock Key) is required when you enter an incorrect PIN 3 times. After entering the wrong PIN 3 times, the card will be locked and you will need to get a PUK code from your service provider to unlock it.
If you have AT&T ;
You can receive your phone's PUK code from AT&T, either by logging into your account at myWireless Account, visiting our Technical Support Chat, or by calling Customer Care at 1-800-331-0500.
Once your PUK has been received, it will need to be entered into your phone to set a new PIN code.
If the wrong PUK code is entered ten times in a row, the SIM card becomes invalid and you will need to purchase a new SIM Card. The phone will display "PUK blocked call operator".
Mar 11, 2010 | Nokia 5000 Cellular Phone
Ford 5000 radio code for serial number M167646
Your code is 0500
Ford  Code Entry Instructions
Once the unit has been turned on the display will show ' CODE - - - -'
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
The set should now operate.
Oct 14, 2009 | 1995 Ford Escort
C-0500 code on bizHub 163
ARE YOU CONNECTED TO A LAN CARD OR NETWORK OF ANYKIND.
GO ON LINE AND TYPE IN
MINOLTA DI2510 B/W COPIER C-0500 ERROR MESSAGE
ENTER
ROD
Feb 05, 2009 | Minolta DI2510 Black and White Copier
C 0500 IN DI 152
turn machine off hold down stop botton while turning on power ,hold down untel machine comes on
good luck
Sep 30, 2008 | Minolta Office Equipment & Supplies
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
