I kept pressing f8 but it only goes to Legacy boot: Sata: CD/DVD/cd-rom drive Other options : BIOS setup Diagnstics
    Brigadier General:
  • 3,400 Answers
DETAILS, what are trying do,or what do you wan't to do.?
what is the problem.?
Posted on Apr 25, 2013
2 Suggested Answers
  • 40 Answers
SOURCE: Can't Boot from "CD"?
need to know what computer and model #
Posted on Jun 20, 2009
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
I am inserting the bootable cd in lg combo but every cd run but bootable cd not run please tell me how can adjust the bios settings
first check the CD you are using is boot able in other system if not write a bootable CD and insert the other thing is of the drive if the drive is old and the lens are weak the boot able cd wont work you will have to find anew drive to test that remove all the ide connectors or sata connectors from the motherboard except the CD drive insert the boot able cd and and restart the system then press del and enter bios setup and click advanced option and make sure the first boot drive is CD then save and exit in some motherboard you need to use f12 to select the boot device then click it and select the boot drive as cd ROM then click click it then you will see after post bios boot from cd ROM press enter it will ask for confirmation press enter again you system then boot from the cd now switch off the computer connect the hard disk and try again
Oct 16, 2011 | Computers & Internet
Bootable cd not read in drive
Oct 16, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
I want to install Windows XP on Sony Vaio VGN CS15GN B instead of Windows Vista but it is not happening kindly help
---------------> Perform a clean install of Windows XP 1)- Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
2)- When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
3)- At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
4)- Read the Microsoft Software License Terms, and then press F8.
5)- Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
6)- Follow the instructions on the screen to complete the Windows XP Setup.
Note:- Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
May 25, 2011 | Computers & Internet
I have a8v-vm motherboard...my ad dvd writer was not working.so i purchased new sata dvd rom but now problm is thai i cant boot from it or instal xp buy this......what i do now..what is the setting in...
Restart your computer.
Press <DEL> to enter BIOS SETUP.
Look for "Boot" options, and change the "Boot Order" to make the CD/DVD the _first_ boot-device.
Save/Exit from BIOS SETUP.
Boot from the CD/DVD drive.
Dec 26, 2010 | ASUS A8V-VM Motherboard
Cannot boot from cd and run setup
When booting, the writing on the black screen should give you a couple of options akin to
Press F2 to edit boot options or
Press "Del" to enter setup. (bios)
You can use either, but you need to set your CD/DVD disk drive as the first boot option.
May 04, 2010 | Microsoft Windows XP Professional SP2
I wiped out my hard drive and cannot reboot through my cd-dvd drive. any suggestions
Ensure that you have your CD-DVD drive chosen as the boot device in your BIOS settings. If you have that setting, then try and boot another system using the same disc you had for your own system.
Aug 14, 2009 | Computers & Internet
I am trying to replace the hard drive in emachine 500is. Now the computer will not recoginize the cd rom to read the windows xp set up disk.
Go into BIOS Setup, and in Boot Order, change the first boot device to CDROM.
How?
To go into BIOS Setup you start tapping either the DELete key, or the F2 key, ->Right After you see the eMachines logo. If you miss this window of opportunity, simple press the CTRL, ALT, and DELete keys, At The ->Same Time.
This will restart your computer. Try again.
If you try the DELete key, and this wasn't the proper key, then use the above, restart your computer, and press the F2 key -> As Soon As You See the eMachines logo.
In the BIOS Setup main menu, look across the top for Boot Options. You cannot use your mouse to navigate around in BIOS Setup, you have to use your keyboard. Press the Right Arrow key to highlight Boot Options, then press the Enter key.
Your BIOS Setup may be different for this model. You may have to go down to Advanced BIOS Settings, in the main menu, and highlight it. Use the Down Arrow key to highlight Advanced BIOS Settings, then press the Enter key.
In the Advanced BIOS Settings sub-menu, look down the list for ->Boot Options. Use the Down Arrow key, and highlight it, then press the Enter key.
In the Boot Options sub-menu, you will see a list of boot devices. Floppy Disk drive, CDROM, HDD, (HarDDrive, or really -> HarDDisk), and perhaps a fourth one.
Use the Down Arrow key and highlight ->CDROM. Look down at the bottom of this menu, and see what the Navigation keys are. It won't state -> Navigation Guide, but that's what it is. You want the -> Change Value, keys.
It may be +/-, or Page Up/Page Down. (Plus + key, or Minus - key)
Using the Change Value key, move CDROM to the top of the list. (You have to hold the Shift key down in order to use the + key)
You may have to highlight the device on top of CDROM, and change value of it, in order to get CDROM to come to the top. Keep moving the boot devices, until CDROM is at the top of the list.
After CDROM is at the top, press the Enter key.
Now press the F10 key to save the changes you made. Now press the y key, and then the Enter key.
If you do not press the F10 key, and then the y key, it will be like you have done Nothing at all!
You haven't saved changes.
You may also have the words -> YES, and NO listed, instead of the Y key. (It's shown as a capital Y for clarity. Press the y key. Do Not hold the shift key down, and press the y key)
You can either use the appropriate side arrow key to highlight -> Yes, or just press the y key.
Now press the Enter key. Your computer will restart.
Your computer will now look in your CDROM drive for a boot disk. (It can be a CD drive, CD burner drive, or DVD drive, or burner)
IF, you do not have the Windows XP disk in your optical drive, or IF you did not get it in your optical drive before the computer booted up, don't sweat it.
Just make sure the disk is in the drive, and then press the CTRL, ALT, and DELete keys,
AT THE SAME TIME. Your computer will restart.
(Not 'shouting')
Jul 27, 2009 | Computers & Internet
Boot from cd
when u power up the computer press DEL or F2 or F10 F12 key to enter bios setup.
then go to boot option then set your dvd or cd as first boot device.
Nov 30, 2008 | Intel Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
