P38 electric window
Power Supply Problem
  • 7,627 Answers
Electric windows in a laptop, sweet. I think you have the wrong category. Isn't a P38 a Aircraft, P38 Lighting? You may want to post the Make and Model of the electric windows.
Posted on Apr 25, 2013
04 Saturn Ion. Power windows and drivers side power lock not working
All power windows not working ? Do you know how to do electrical testing with a test light or DVOM - digital volt ohm meter ? How to use a wiring diagram to locate the circuits to be tested ? Videos on youtube The Trainer 24 Power Window Troubleshooting You can find free wiring diagrams at http://www.bbbind.com/free_tsb.html .Pull the door panel to access the window - lock switch , Test power supply and the ground . This is how we diagnose electrical problems
Feb 11, 2017 | Saturn Cars & Trucks
2005 buick lacrosse 3.8LV6 .. All power windows dont work and radio wont turn on ..what can this be
You would need to test the electrical circuit to find out what this could be . Videos on youtube for basic electrical trouble shooting !
Are all the power windows inoperative?
YES - Go to Step 3
NO - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
    Disconnect the driver window switch C2 harness connector.
  1. Turn ON the ignition, with the engine OFF.
  2. Probe the power window switch voltage supply circuit of the harness connector with a test lamp that is connected to ground.
Does the test lamp illuminate?
Yes - Go to Step 4
NO - Go to Step 5
Connect the test lamp between the power window switch voltage supply circuit and the ground circuit of the harness connector.
Go to Step 6
Go to Step 8
5
Test for an open or a short to ground in the power window switch voltage supply circuits of the driver window and front passenger window switches. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 11
Go to Step 10
6
Test the power window master switch lockout signal circuit for a short to ground. Refer to
Go to Step 11
Go to Step 7
Jul 21, 2016 | 2005 Buick LaCrosse
Range rover P38 1995 2.5 Diesel auto .would not turn over all lights and Windows working new battery ok yesterday
when you lock it up does the alarm activate you say this problem only started after changing battery sounds like its the mobiliser lock and open car from inside with key in ignition hope this helps
Mar 14, 2015 | 1995 Land Rover Range Rover
Need winxp wifi driver for hcl p38pdc laptop
You may try having a look here :
http://laptop-driver.blogspot.com/2010/10/hcl-notebook-p38-pdc-windows-xp-driver.html
if you are having trouble finding the appropriate drivers for your HCL P38 PDC laptop then you should download Everest from here
You can also seek HCL support for more help
Aug 11, 2011 | Computers & Internet
My 99 P38 4.0 has the rl7 relay area burned out of the fuse box. After milking it to long replacing relays to run the fans in the FL heat, I lost my climate control display and radio. Then it started...
The fan relays in P38 Fuse boxes burn up to to clogged air pollen/cabin filters (located below the lower front windscreen cowling, beneath an oval shaped cap, one on each side of the car). When these get clogged, the fans work too hard, and eventually burn out the relay as well as the board (mobo) in the fuse box.
Another reason for power loss in the P38, is the wiring to the alternator getting too hot, and cracking the wire housing, allowing for power draw.
GD
Aug 11, 2010 | 1998 Land Rover Range Rover
Where can i download bluetooth driver for hcl p38
http://203.76.139.132:8080/examples/jsp/download/pon_index.jsp
Aug 02, 2010 | Compaq Computers & Internet
RANGE ROVER P38, PARKED UP NO PROBLEM , NEXT MORNING TURNS OVER WITH NO SPARK AND NO FUEL??CAN ANYONE HELP
This also happened to my P38, parked at night ok and next morning nothing.
I had a BBS faultmate which when connected told me that 'the engine ecu had not received the code from the BeCu in the specified time'.
I'd had enough by this time and sold the car and the new owner send both these ecus away to get reprogrammed (at a cost).
This may or may not be your problem, it could be an immobiliser fault but being a P38 (loved mine by the way despite all it's foilbles!!) it could be any one of a number of things.
Really without diagnostics your p***ing into the wind with a lot of the faults in a P38 I'm sorry to say.
Sorry not to be more of a help and good luck with it.
Iain
Oct 04, 2009 | Land Rover Range Rover Cars & Trucks
Drivers for hcl notebook p38 pdc
how can i get lan driver for hcl notebook p38 pdc
Sep 19, 2009 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
