Question about HEWLETT-PACKARD Black 20" TouchSmart 310-1033 All-in-One Desktop PC with AMD Athlon II 240e Processor, Windows 7 ... (885631689134)
Sudden Shutdown I will be surfing the web or listening to music or not doing anything on it and it will just shut down like I unplugged it or something.I don't have a lot of programs running or anything like thta. So I dn't know what the deal is
  • HEWLETT-PACKARD Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing & replacing the PC's power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty although very rare for sata lead to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
You might have a virus or malware.
Download at least one of these of course it will depend on your operating system.
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
Posted on Apr 25, 2013
Shut down on hpm7570n
I need info what webcam dop you have what do you use to listen to music and what os !
Mar 01, 2012 | HP Pavilion 735n Notebook
Computer shuts down when listening to music
common reason why system shutdown automatically is if the motherboard is overheating where the system fan is not running. double check first the status of the computer if you are still able to hear any spinning sound or some air coming out from it. if those scenario is not applicable what are the other symptoms of the auto shutdown other than listening to music?
Feb 25, 2011 | Microsoft Windows XP Home Edition Service...
Sudden shut down for VGN CS16G
there is virus in bios or fan is not working properly.
Jul 16, 2009 | Computers & Internet
Screen turned off and when i pressed shutdown it wont shutdown
Hold the shutdown button for 15 seconds (be sure to count slowly). If this still doesnt help and you ABSOUTELY need to solve this issue, then you can try to risk removing and reinstering the battery pack of your laptop.
I tsounds like your laptop overheated. it should return the normal once it is rebooted.
Jul 02, 2009 | HP Advanced Port Replicator 1.2
Hi. I have a new Asus laptop with Realtek HD
Hello kindly reinstall the your sound card driver and update all plug in support that supports your music and sound.
Thanks
Jun 06, 2009 | Computers & Internet
System shuts down when playing music dvds at 17 or 18
Check your speakers one by one, maybe one of them are about to burn that´s the reason your device turn on protection state,good luck
Mar 16, 2009 | Televison & Video
Power loss
Its possible that one of the speakers wires are shorting out or touching the case of the unit (leads to protective shutdown).
Sep 14, 2007 | Onkyo TX-SR501 Receiver
Shut down problem
If you can go to Safe Mode, try to open command prompt from there. Have your Winxp Cd ready. Type sfc /SCANNOW
Aug 20, 2007 | Microsoft Windows XP Professional With...
HEWLETT-PACKARD Black 20" TouchSmart 310-1033 All-in-One Desktop PC with AMD Athlon II 240e Processor, Windows 7 ... (885631689134) Logo
Top HEWLETT-PACKARD Computers & Internet Experts
Bilal Ahmed Qureshi
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
