Question about Vocopro Audio Players & Recorders
I have a vocopro kjm 7900 audio mixer that no longer powers on
Unit was working fine but sat for 3 months and now does not power on.
Have you checked all the wires on the inside of the stereo
Posted on Apr 25, 2013
  • Roger DeMarco Apr 25, 2013
    Not yet. I was just checking the fuse which seems to be intact
Mackie mixer problems
Don't think it's a heat problem; sometimes the electronics just get confused and need to have power cycled. Try turning power off at the rocker switch, wait 10 secs., then turn it back on. If that doesn't clear the problem, try the same thing by unplugging the AC cord. If nothing changes, it may be time to call LOUD tech support - 1.800.898.3211
Sep 02, 2014 | Mackie Onyx 1620 Mixer
How do I get my audio mixer to record after the power light died?
A power supply device has shorted due to:
1) Age - shouldn't be the case.
2) Misuse - hooking up to an older tube type amplifier or older tube type equipment without polarizing the power.
3) Component failure - This can happen at anytime.
4) Power spikes due to the utility company or lightning.
Suggest calling Support at Behringer to. Usually the manufacture wants to rectify any service situation especially on such a recent model. Who knows! They may have had a problem with that unit.
Depending on model and original purchase cost you may be better off purchasing a new unit.
The older Behringers' are not known for quality merchandise - usually sold at Guitar Center.
May 20, 2014 | Behringer Xenyx X1832USB Premium 18...
No power from amp outlets ..rest of mixer works fine
The amp module has likely blown. Repairs can be exetensive within the module. Try cycling the power as there is an overcurrent sensing in the amps that locks the switching signal off. Let the unit remain off for several minutes and retry it. This all assumes it has worked before and the cables are good. Also please read my tip on here about PMP mixers regarding a hazard on the A output when using Speakon to 1/4 inch cables. The A output s;leeve of a 1/4 inch jack is the HOT, NOT the tip of the plug, unlike the B output.
Apr 03, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
Humming noise since adding a vocopro DA-1050pro mixer to our system.Have connected a ground loop isolator but it makes no difference.The mixer is the only change in the system
Make sure ALL interconnected equipment is powered from the same receptacle or source such as power conditioner. This isncludes mixers, amps, CD pllayers, etc.
Second make sure ALL interconnecting cables are BALANCED lines using XLR or TRS cables.
Isolators other than DI boxes are a no-no.
Mar 30, 2011 | Vocopro Da1000pro Professional Digital...
I need a channel slider for a vocopro mixer KJ7000
various types are avail at mouser and digi-key .com. google them -check their catalogue and search under potentiometer.verify value,physical dimension and shaft length.
Mar 03, 2010 | Vocopro Kj7000pro 19" 6 Channel Karaoke...
No Power to Control Center, Line inputs no longer appear in mixer
It's 80% from the AD_link cable between the internal driver and the Hub
Hope this helps
Jul 04, 2009 | Creative Labs 70SB038000000 SB0380 Audigy...
Power surge thru pioneer powered subwoofer into the receiver
Cheaper to replace the unit labor and parts costs being what they are.
Jul 01, 2017 | Pioneer VSX-36TX
Vocopro VHF-3300 Dual Wireless MIC - one is lower than the other
If the unit was "repaired" correctly, you would not have that problem! Have repairs been attempted?
Apr 18, 2017 | Vocopro VHF-3300 Microphone
41 people viewed this question
Top Vocopro Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Vocopro Audio Player and Recorder Expert? Answer questions, earn points and help others
