Question about Husqvarna Garden
Mower governor Where is this located?
  • Husqvarna Master
  • 7,482 Answers
Hi Rodney
The governor for the engine is located inside of the motor...the arm that works the carburator is outside and attached to the carb
Bud
Posted on Apr 25, 2013
My john Deere 110- 42" cut lawn mower ran out of gas and won't crank back. Noticed the parking brake is engaged but will still roll. What is my problem?
Hi Shannon, It's either fuel OR electrical, First check electrics, If it cranks but not starting......
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 29, 2016 | John Deere Garden
Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Sep 23, 2008 | Garden
LAWNMOWER ENGINE RACES BADLY - HOW DO I FIX IT
Sounds like your governor linkage and or governor control fan arm " most small engines have them to control over speed" is binding or maybe has dirt and grass built up.. Or the return spring is disconnected. Once it starts to race manually move the governor linkage back an let go see it it stops racing.. Then release if it races again..check the spring if connected...you must check the governor fan it is located under the top housing..it uses the engine fan calling air to slow the engine when over speed occurs by pushing the governor linkage back to slower speed.. Check it out...good luck..
Apr 25, 2015 | Garden
Air vane spring location
Dose your motor have a manual choke or automatic?
Jan 26, 2015 | Garden
Champion lawn mower Starts but revs flat out
your governor spring may be in the wrong hole. start engine and move governor arm either way. one way should slow engine down. if this is the case then move your spring to a location that will hold arm in that spot. if this is not the case then you may have a broken or damaged flyweight on your governor inside engine
Oct 17, 2014 | Garden
Hi, I just need to replace the spring governor, but because the old one was broken I am not sure of the placement of the new spring, I have been trying to find a diagram so that i can see how it connects...
Kmossman,
There are many different set ups for governors. Typically the spring goes from the arm of the governor shaft ( the one that comes out of the block) to an extention on the throttle shaft. If you have a better picture (larger) you can send me I should be able to mark the locations for you.
Chris at iaff801@snet.net
Jan 09, 2011 | Briggs & Stratton Briggs Stratton...
Engine starts easily, but runs flat out, no matter what the throttle setting is. Ignition cut out still operates correctly.
I am not sure what type or how old your mower is but most have whats called an "air vane governor". This system uses air flow and a spring to control a vane back and forth. One problem is debris sometimes collects in the system blocking air flow. When this happens the engine will over speed. The other is if the spring breaks or detaches from the governor.
You should avoid running the mower at all until you are sure you have found and fixed the problem. Over running can quickly cause catastrophic damage to the engine.
Inspect the governor and make sure it's moving freely and that there is no blockages in regards to the air flow. If you find that the governor is not moving freely you can attempt to control it manually when the engine is started but only after you have positively identified the governor as the problem.
If you are unsure where the governor is located please respond back with the make and model of your mower.
Hope this helps.
Dec 04, 2009 | Garden
Need pictures of governor springs and governor
model # 12f702-1824e1 mower( that uses weedeater string) had a spring come off the carberator and I don't know where to put it back on.
Apr 18, 2009 | Briggs & Stratton Garden
Replacing governor on Cub Cadet 1225
I have a cub cadet 1864 and the governor is out of control, the engine will race a high speeds. When i pull back the governor arm and hold it it run normal. Can some one help
Apr 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
308 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
