Question about Home
Aqualisa Axis thermo fitted with a Mach 250 pump. Shower stops after approx. one minute. Have cleaned the strainers but still a problem.
Shower pump stops after running for about a minute. Have cleaned the pump strainers but still no better
5 Suggested Answers
  • 148 Answers
SOURCE: Our Aqualisa power shower lacks water pressure power
more than likely you have some debris near the shower head
take an adjustible wrench( crescent or channel lock
wrap a rag around the eustaceon( chrome tube coming out of shower wall srap around tube to protect the chrome hold it firmly with vicegrips or channel locks, take adjustible wrench or chanel locks and remove the chrome nut holding the shower head on to the eustaceon(turn counter cockwise be careful not to drop the tools that wil damage the tile or fiberglass
after removing showerhead
turn on shower to force and debris out and place shwoer head into stream of water to clean out any deposits the head may have some type of screen to strain the water
this should work if the flow has not incresed then there is a need to adjust the flow valve at the control
to reinstall the shower head reverse procedure
if you have any teflon tape wrap it around the threaded portion of the eustaceon
good luck
hoe this works
Posted on Dec 30, 2008
SOURCE: Aqualisa Aquastream shower noise from pump/motor ?
aquastuream loud noise?motor/pump
Posted on Sep 04, 2009
peterrance19
  • 399 Answers
SOURCE: Aqualisa quartz shower. Knocking / dripping type
this is caused by the water pressure in the pipes check that all the pipes are secured firmly this should stop the problem a piece of rubber or foam placed behind the pump will also help
Posted on Nov 16, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a HE2. It
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks!!
Posted on Sep 10, 2010
Can still hvee a shower put no power electric is going to it but not to tranformer could it need replaced
usualy u have to have a filter, before pump, if the filter is dirty u will have no presure, but i need to know if the pump starts or not, u can try to clean the filter, for more advance testing u need to have a litlle knolege, hope will be ok, is the easy way whit all the machines that are conected to water suply a filter can be check by all persons
Mar 07, 2017 | Home
My Aqualisa Quartz shower stopped working suddenly. Pump is on, but no water
can offer no information on this but to call a local plumber .sounds like you possibly need a new pump
Aug 01, 2016 | Home
My feltonmix shower has stopped supplying cold. I have adjusted the cold tap in the wall but which worked for couple weeks but now won't word at all. Any DIY solutions or get the plummer?
Possibly there's a strainer/filter on the cold that's plugged up. That would be a normal homeowner project to remove and clean the filter. You will want to check the Feltonmix site for instructions:
Feltonmix felton There's a picture on the page showing the strainer.
Jan 02, 2015 | Home
6 yr old Aqualisa shower working perfectly well. But turned itself on last night. No light showing on dial/on switch. Wouldn't turn "off" for me. Ran for 15mins and then switched off!
Good Aternoon lrmulholland,
Do you know what model Aqualisa shower you have or are you able to take a photo of it for us? That would be very useful.
Kind Regards,
The Aqualisa Team
Sep 07, 2011 | Vacuums
Hello, my aqualisa shower is working intermittently, water starts and then goes down to a dribble, but not all the time. It is an aqualisa quartz.
If you are not getting any water through your shower it is possible that there is a restriction.
Please note that the air lock test is only neccessary if you're shower is the Pumped Digital Quartz or Quartz Thermo Mixer Shower and that you are on a Gravity Fed Water System (cold tank in loft).
The hose will appear fine from the outside,but the hose has an internal rubber liner which can become blocked/twisted.
To remedy this,unscrew the shower head from the hose anti-clockwise.Place the open end of the hose to it's lowest point (bath or tray).
Turn the water on.The water SHOULD come out in a straight line,if however the water comes out in a V-Shape the liner is twisted and the hose will need replacing.
Air Lock
If there is air in your pipework this will cause low flow and pulsing.To remedy this fault do the same above but run the water on FULL COLD for two minutes and then FULL HOT for three minutes.
If the water pulsates it is the air escaping.If it does this leave it until it corrects itself.
Hope that this info helps you,if it doesn't it sounds like you have a mechanical fault with the processor box.
Aug 24, 2010 | Kitchen Ranges
Aqualisa shower will not stop dripping after use. what is needed?
If you can confirm what model of shower you have I can talk you through how to repair the shower,<br /> <br /> Mike<br /> Aqualisa Showers
Aug 15, 2010 | Home
Get a knocking noise from an Aqualisa Quartz 2
It may be a water hammering effect from pressure in your pipes. You may need to install a water hammer to stop this. you can put in line that will stop this.
Dec 28, 2009 | Home
Aqualisa quartz shower. Knocking / dripping type noise coming from pump when powered but not turned on. Any ideas???
Nov 15, 2009 | Home
Mar 30, 2009 | Home
good luck
hoe this works
Dec 27, 2008 | Home
Home Logo
44 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
