Lg wd 10165fu
Error code FE
SOURCE: LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Posted on May 28, 2009
  • 1382 Answers
SOURCE: Faulty water valve on LG WD-12320rd washer. Code
FE means Fill Error. If you unplug the machine and it still fills, and the only way to stop the filling is to turn off the valves supplying the water to the fill hose(s), then you need to replace a fill valve. It is best to figure out which one by turning one off at a time while the machine is in that FE condition. There is a separate hot and cold valve. (they are the part that the hose screws onto on the machine.) To replace valve, cover comes off machine by removing two screws at the back of the top. (not the two which go into the top, the ones just below them) Then, standing in front of the machine, use the palms of your hands to give the top a sharp push to the rear to slide the top back about two inches. Then lift the top off.
Posted on Apr 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: "FE" Error code on Lg Washer #2277HB
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • 5 Answers
SOURCE: My LG WD 10165FU displays
CL IN MANUAL STANDS FOR CHILD LOCK. MANUAL SHOULD TELL YOU HOW TO TURN OFF. IF YOU HAVE NO MANUAL GO TO WWW.LG.COM/AU PRODUCT SUPPORT TYPE IN MODEL NUMBER AND DOWN LOAD PDF FILE.
Posted on Feb 22, 2011
mc1bean
  • 3053 Answers
SOURCE: i have an LG 7.5kg
Hello there, Ok, first check under the lid, there is a peg that goes into the top edge of the washer. That is a switch. The idea between this is that it is a safety feature for mostly kids, so that when the washer is on that high speed spin cycle, that a child does not open up lid and stick there arm or hand in and have it injured. Most washer are designed so that the washer will only spin when the washing machine lid is down. So, of course you have it down, but sometimes the lid might have got a little bent or warped. So first try with lid down pushing down on lid while on spin cycle. If still wont spin, most likely it is that switch that that peg goes into, if you take a knife or flat head screw driver, with lid up on spin cycle and push into that hole with the knife or flat head screw driver and do not here a click when pushing it and releasing it, then you need to replace that switch, it is pretty cheep, normally under 20 bucks and a appliance store and when picking up the part they can tell you exactly how to replace it yourself, it is pretty easy and only takes a few minutes. Hope this helps. Mike Please select a 4 thumb up, if this helped you, and atestimony if you like. Also take advantage of fixya expert assistance live. For a price, expert works with you while you work on your washer or anydo-it-yourself project. Fixya is always less expensive than a service call.
Posted on Jul 26, 2011
LG 7.5 wd-10165fu when spining on 1000 makes a noise like its touching against the side of the machine
If tub is banging around it could be dampers, but if it's a scrapping sound then something is caught in the inner tub and at hi speed it touches the outer tub.
Apr 23, 2017 | LG Washing Machines
Hi my LG 7.5 kg (10165fu)front loader washer has just stopped functioning. It shows on screen a big "CL".What do i do? Pls help. Griffiths
CL means that your washing machine's CHILD LOCK is ON. You can find two buttons Temp and Options in the panel. Turn ON the machine, press these two buttons together for 3 seconds and thats it. It might have a little kids face above a lock key, inbetween the wash and rinse buttons, hold these for 3/5 seconds and it should work
Dec 03, 2016 | LG Washing Machines
Hi. How do I reset my LG wd-10165fu washing machine? I cannot get the CL (child lock error code off. Thank you
have u tried unplugging it for 10 minutes then plugging back in sometimes this will reset it other wise u have to check ur manual for reset options
Nov 20, 2016 | LG Washing Machines
How do I remove child lock from lg washer WD 10165FU
Push child lock or key symbol button for three seconds
Feb 24, 2015 | LG Washing Machines
Error FE on a LG WD 1274FHB what does it mean?
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Feb 15, 2015 | LG Washing Machines
My LG WD 10165FU displays CL and does not switch off. What should I do?
Dec 27, 2010 | Washing Machines
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
