Question about Sony Ericsson Walkman W810i Cellular Phone
Blinking my phone just keeps blinking every time i try turn it on, even when i put the charger on it still blinks. what could it be, i havent dropped it or damaged it. please help its fustrating me. thanks.
I think it happens due to internal loose connections....
Posted on Jan 24, 2008
Only one solution.... sell your set.it happened to me.i wasted a lot of money for booting its software.it is a software problem dearrrrrrrrrrrrr
Posted on Aug 06, 2007
My scooter will not work even when i put the key in the3 ignation it does absolutely nothing not even a click i got a spark and he checked all the fuses and every thing is normal it just wont turn on
Number one make sure your harness connections are good. Then check with a meter that power is going in the controller. Check output of the controller. If you are near the controller look for fuses. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Aug 23, 2016 | Health & Beauty
Xperia u dont turn on just red led blinking after charge up
I experienced the very same problem twice.
The red led would either stayed on all the time when charger was connected or it blink whenever I'd push the power button on the phone, but the phone would not turn on.
My solution was to unplug the charger, take out the battery and the sim, keep them separated for at least 48-72 hours, then put back the battery, connect the charger again (don't use your computer's usb port, use a real wall charger, preferably the original one), turn on the phone.
If it doesn't turn on immediately, let it charge for a few hours and then try to turn it on.
I revived this phone twice using this method, first time I thought I was just lucky, but apparently it's reproducible.
Hope it works for you too.
Apr 04, 2013 | Sony Ericsson Xperia U Black Rubber Gel...
I have an HP F4480 printer and i have used it before. I haven't used for days and when i used it again a problem occur. As i plug the power cord to the outlet, the power button keeps on blinking even if i...
Hi. Try pulling the ink cartridges out of the printer, turn printer off, then on again. When asked for ink cartridges, insert only one at a time.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 01, 2017 | HP F4480 All-In-One Printer
Phone not turning on keep beeping red light. phone make. sony ericsson w580i
Your battery is probably out of charge.... Try charging it.... If the red light keeps on blinking even after charging it for a sufficiently long time You will either need to
1. Change your Battery.
2. Perhaps change your charger.or get your charging port checked and repaired.
Nov 04, 2010 | Sony Ericsson w580i Cellular Phone
My blackberry 8320 wont turn on no blinking nothing not even
Try a new battery or have your battery charged on another 8300 series phone, then install it in your phone. Typically, if the battery is below a certain voltage ("dead") the charging circuit does not become active, therefore not enough voltage to turn on your 8320. Also if it has been dropped or got water damage, these can also cause that problem.
Mar 06, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
My HTC p3300 battery not gettin charged. It works on direct power for some time and get automatically shutdown after some time..indicating no charge. Keeps shutting down often.
I too have been experiencing problems. Replaced the battery but it happened again. The battery says it is at almost 100% capacity however several times in the day, when I go to turn it on it doesn't respond. I end up taking the battery out and then have to connect it to a charger (USB) so that the charging light blinks red once and then turns off. I can then put in the battery again and it will start up again. If I don't connect it to the charger cable to drain (get the red light to flash once), and try just putting back in the battery, I've noticed that the screen has a faint glow as though it was on but the screen is completely blank. I'm starting to think that there must be a short circuit somewhere because I'm going to assume that the new battery is good.
Feb 20, 2009 | HTC P3300 Smartphone
I have no clue on what happened!
Sounds like a huge tech. problem, I would contact your purchaser instantly, have you tried taking out your sim card and seeing if it still does this? Another this, If your phone got wet, It could be doing this, It has done this to me before, and If it did get wet I hope you have water insured! Ways to get water out are putting your phone in the freezer for a day - That is, if it got wet.
Nov 29, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Dead Phone
I have the exact same problem. It is completely dead but sometimes when I go to turn it on the screen will flash white and the speaker will pop. I tried different batteries and different chargers and I have no idea what the problem is.
Mar 10, 2007 | Motorola Mobility V265
Sony Ericsson Walkman W810i Cellular Phone Logo
57 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
