Question about Garden
I have a problem with the carburetor Polaris Ranger 500 2006
Hello everyone. I have a problem with the Polaris Ranger 500 2006. At high rpm is working fine. When it warms up it shuts off when I stop. It drives back without a problem. But every time he turns off again when I'm idling. I cleaned the carburetor replaced the jet needle, needle jet, needle valve and set. But it did not help. Could be the fuel pump makes the problem? By the way I changed Peleg, Fiiltr air Fiiltr oil, engine oil, and replaced the Clutch Drive in New. New belt. All the originals of Polaris parts by part number. Oh one more thing, I adjusted the air screw two rotations.
michigan man
  • 3533 Answers
SOURCE: engine idles rough, misses at 2500-3000 rpm's
i would first check the timing and if that does not fit i would take the cover back off and look at the belt for a bad or missing tooth
Posted on Feb 14, 2009
SOURCE: Engine only idles under full choke
You are right the carb needs to be cleaned you can do it your self but i suggest you get a service manual or at least count how many turns in (lightly seated) on your adjustment screws before taking the carb apart. also any rubber seals and gaskets need to be replaced. carb cleaners in a can work ok. but to really get a carb cleaned it needs to soak in a solvent completely dissasembled the rubber seals will expand so make sure it is COMPLETELY DISSASEMBLED
Posted on Mar 20, 2009
  • 190 Answers
SOURCE: Cleaning Carb Jets
not to a trained ear also go by rpm and spark plug color
NOTE: use copper wire to clean jets, sync is just thottles are same position as all carb's just leave them adjustments alone will be fine if are out use a 1/8 drill an place in between piston/butterfly to carb bore to sync/calibrate
better use a manometer for adjusting screws
depends on condition of org parts
worn = richer running
new = lean an clean
also if changed the exhaust system need to
re-calibrate carbs for max performance
Posted on May 09, 2009
  • 22306 Answers
SOURCE: I have a toyota camry 1997, 4cyl. When I'm driving
could be the coil pack playing up ,or the computer not working properly ,very difficult to diagnose without the right software so i would suggest taking it to a dealer and see what they say
Posted on Jun 22, 2009
SOURCE: My KTM lc4 640 running problems
Check your valves. they might be tight. possible shimming required there to get them back to spec
Posted on Jul 01, 2009
Where to find the serial number on polaris ranger
this is all i can find on the internet about it.
Where to find serial number on Polaris Ranger? Whenever corresponding about a Polaris RANGER utility vehicle, be sure to refer to the vehicle identification number (VIN) and the engine model number and serial number. The VIN can be found stamped on the lower frame rail on the front LH side of the vehicle (see Figure 1-1).
2011-2012 RANGER 800 XP / HD / CREW / 6x6 Chapter 1 - Asap911 Search for: Where to find serial number on Polaris Ranger?.
how to find vin number on polaris ranger Google Search
Oct 31, 2017 | ATVs
I have a 2005 Polaris Ranger 500 with Carburetor fuel system. After running for 30 minutes or so it will stop and will not restart. Let it set for an hour or longer, it will restart and run fine.
Sounds like the a component of the ignition system is defective, as to which part you will need to determine that by testing. It can be scanned for codes by the dealer to help in diagnosing.
Jan 23, 2017 | Polaris ATV
Will not go above 20mph in high gear.
Cant accelerate over 20mph - Polaris RZR Forum - RZR > ... > Technical > Engine and Drivetrain
Jul 22, 2010 - This is a discussion on Cant accelerate over 20mph within the ... The oil is not a problem, what RPM is the engine turning? and are you 100% sure your in high gear? ... DeeZee 35X14X12 Cargo Box, Super ATV Steering Wheel And EPI Severe Duty Belt .... why wont my 2015 polaris ranger go over 20 mph.
Oct 01, 2015 | ATVs
Polaris idle
you need to check for a vacuum leak. Spray carb or brake cleaner around the intake. Everywhere possible and listen for an rpm change when you spray. make sure you are thorough. this would be a good start.
Sep 02, 2014 | Polaris 2013 Ranger Mid-Size 800
Polaris Ranger 6x6 700 EFI. Began idling high and not shifting and within a few minutes began to loose power and bog down when attempting to accelerate. Would not move under its own power but would idle at...
Based on information provided I would start with just checking the basics as far as servicing goes, starting with air filter, is it clean, and is there anything preventing it from breathing easily. Check the accelerator cabling, might be dry, stuck or mucky somewhere from pedal to carburetor that can cause similar problems. Check oil level of motor as well.. Hope this helps
Jan 05, 2018 | Polaris ATV
1985 Ford Ranger RPM seems too high when first
I would check for any vacuum leaks. Also, is the check engine light on?
May 11, 2010 | 1985 Ford Ranger
I'm trying to solve a sperformance problem with my
Replace the sparkplug boot on end of wire its starting to breakdown and carbon track internally!
Apr 14, 2010 | Polaris ATV
High idle problem on 2009 Ranger Crew (700 cc/fuel injection).
If under warranty then bring it back. If you like the way the dealer does its work then go back otherwise find another local dealer to take it to. It could be a sensor that is bad.
Oct 26, 2009 | Polaris ATV
Backfires at half to full throttle, idle is ok, low rpm
change Your spark plugs. If that doesn't help the carburetor needs to be cleaned and checked. Hope that helps.
May 24, 2009 | Polaris ATV
Garden Logo
50 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
