Question about Dyson DC25 All Floors Bagless Upright Vacuum
Reset button ON DC25I
BRUSH NOT WORKING
Dyson created a good vacuum cleaner but it seems odd that this problem of sucking a shoelace would disable your vacuum cleaner. I even replaced the head. PLUS they want 150 dollars to fix. Come on, if this where Dyson is going, to create something that's going to cost 100's of dollars to fix, then DO NOT BUY DYSON! They did send me a new head but my head still won't turn even after resetting the electrical button. I BET it's an easy fix. Lucky all we have is hardwood floors but frankly it would be hard for me to suggest to someone else that Dyson is the best. A product is ONLY as good as the warranty behind the product.
Posted on Sep 14, 2013
How do I fix the brush bar reset button on Dyson DC24?
Hi there, it's Jack at Dyson.
The reset button will not remain depressed after it's been pushed. Instead, you should hear and feel a click when pressed - it can help to use something like the eraser-end of a pencil. The steps are shown in our video guide below:
If you've been unable to reset the cleaner head after pressing the reset button as shown, or if you're worried the reset button isn't working correctly, please get in touch as we should be able to help you further.
You can reach the Dyson Customer Helpline directly by calling us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Please have your DC24 to hand when you call so we can take you through some troubleshooting checks.
Aug 15, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
Reset button inoperative
Sounds like 1 of 4 possibilities
1.The button next to your on switch is jammed.
2. The Motor has burnt out within the head unit
3. The PCB Unit is faulty wihin the head unit
4. The thin wires running down the inside of the machine to the head unit hve br
May 23, 2014 | Dyson Dc-18 "slim" Upright Model...
Dyson brush wont turn
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first.
Oct 08, 2012 | Dyson DC25 All Floors Bagless Upright...
Dyson DC14 reset button location
go to http://content.dyson.com/support/?basketTotal=0.00&basketQty=0&logged=false
proceed with your models, and see videos or troubleshooting or video for to se the reset button.
God bless you
Aug 02, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
The powerhead brush died. The vacuum works just fine, but the brush doesn't.
there could be 2 reasons for this problem.
one) the powerhead is dead legit as in there is no power coming to it or the motor is actually dead.
2) something jammed in the brush and popped the reset button. The reset button is a red button located as your looking at the back of the powerhead on the right side. Usually a red square. Push it and it SHOULD start up again.
That being said, if you have done the reset button and it still does not work, that unit I beleive has either a 2 or 5 year warranty (cannot remember dont have the documentation in front of me) and if it is still covered under warranty for you, take it to your closest Vacuum repair shop. Do take the hose and powerhead with the cannister unit.
good luck
Nov 06, 2010 | Electrolux EL7020A Oxygen 3 Ultra Canister...
I have a kenmore progressive vacuum with a belt reset button that trips out everytime you try to vacuum. It does it in about 5 to 10 seconds. Can I bypass the reset button or can you help me determine...
A lot of times the reset button is tripping because there is a problem. The problem could be with the brush roller in this case. A lot of times I see this unit for repair and the end of the brush is so compacted with hair and debris that it has also started to melt. This will also "fool" the reset and trip off. If you are near a service depot try there, or try sears parts if you need to have the brush roller replaced.
Bypassing the reset button is not advisable on any machine.
Nov 03, 2010 | Kenmore 25614 / 25615 Progressive Bagged...
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Kenmore Beltless Vacuum brush will not spin. Everything else works.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
Jul 23, 2009 | Vacuums
Premalite vac brush stopped turning
Not familiar with thi sbrand, but a reset is for when the brushes get jammed pr stalled, it will trip the reset. Make sure that the brsuh roll turns easily, also for a broken belt and/or bad brush roll. Some resets are for when the vac motor over heats, it will trip saving the motor. Usually this is for a jammed brush roll or a clog.
Apr 23, 2008 | LG Electronics Premalite Vacuum Bagless...
Dyson DC25 All Floors Bagless Upright Vacuum Logo
96 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
