Question about Singer Sewing Machines
How to thread the machine
Having hard time theating correctly..Machine works Model ## SC-L1
  • 29 Answers
Are you sure that's the correct model no?
Posted on Apr 25, 2013
4 Suggested Answers
  • 12 Answers
SOURCE: thread constantly wraps around spool pin
Cut a round curcle of fabric the size of the spool from a piece of felt. Put a hole in the middle and put it under the spool of thread. If this does not work you can purchase a small net that fits over the spool. It is designed to keep the thread from coming off the spool except for being pulled through naturally.
Hope this works.
Zelma
Posted on Jan 19, 2008
yeroc
  • 397 Answers
SOURCE: The top thread will not grab the bobbin thread to complete a stitch.
its common, but easy to fix,,,ok......first things first, 1. bobbin in bobbin case correctly 2. machine threaded correctly 3. tension set around 3-4 upper 4. when was the last time machine was serviced
Posted on Jan 21, 2008
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
How to solve the err 071 of SC 810 control box of Juki
Hi Mohamed
regarding Error E 071 of SC-810 control please check :
1- thread trimmer cam correct adjusted or not.
2- there is a lot of thread into motor pulley or machine pulley.
3- if error E 071 coming immediately when turn power ON means problem inside control box, to confirm that please put working control box on machine , if error remove means problem at control box.
best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Mar 02, 2015 | Juki Sewing Machines
I am having issues with threading my machine. I have followed the instructions but every time I sew on the machine the thread on the top sews correctly but underneath the cotton gathers up. What am I doing...
If the thread is bunching under the material it is the top tension. While threading the machine be sure the foot is in the up position until you are done threading it. If you have tried that and it still bunches you need to tighten the tension a bit at a time until it starts sewing correctly. Be sure you are starting with a clean machine and that the thread is not too large for the needle ....
hope this helps.
Nov 25, 2013 | Brother LS 2160 Sewing Machine
Elna Lock L1 won't keep thread chain
for a manual try elna customer service
as for the needle, check to see if it's inserted correctly in the needle holder
the needle must be pushed all the way up into the needle holder--
the flat side goes to the back side of the machine
you also mentioned that you broke a needle, when a needle is broken some times it can cause the machine to go out of time, which means it has to be taken to a sewing machine repair shop & be retimed,,
and it needs to be serviced.
Mar 01, 2012 | Sewing Machines
Can not pick up thread from spool
First check to insure that machine is threaded properly, and thread is not binding. Next check to make sure that needle is in machine properly (facing correct direction and fully seated) If you are still having problem check the bobbin case ( does bobbin turn correct direction when thread is pulled?) You will have to refer to your owner's manual to verify this as not all machines are identical (but usually the correct direction is clockwise) If still having problems you may have a problem with timing of the machine (usually after a bad fabric jam) If this is the case you will either need a service manual or need to take the machine to a qualified technician.
May 16, 2011 | Sewing Machines
Beginner on a sewing machine just got a Euro- Pro from my aunt having a hard time getting it to sew something. I threaded it and ready to go now it wont sew soooo what might be wrong with it?
See if you can find your model here and refer to the instructions to see if you missed something when you threaded the machine - http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Always thread a sewing machine with the presser foot up so the thread enters the tension so it will properly work when the foot is down for sewing.
Check the needle to be sure it is inserted correctly - this is usually with the flat side facing the back of the machine.
Hold onto the thread tail at the needle and handwalk the needle down and back up, which will bring up the bobbin thread.
Hold onto both threads and pull them under the presser foot and to the back of the machine.
Place the fabric under the presser foot. Lower the foot and move the needle down into the fabric - press the foot pedal.
Feb 28, 2010 | Euro-Pro Sewing Machines
The bobbin thread appears up through the hole by the foot, but the needle doesn't seem to be picking it up and advancing the thread properly, so when I sew, the bobbin thread isn't engaging. I have a JC...
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Best Wishes Martyn
Bargain Box in Australia
Sep 07, 2009 | Sewing Machines
Model No. 15358. I am having problems with my
Sep 04, 2009 | Kenmore 15358
Jan 20, 2008 | Brother SE-270D Computerized Sewing...
Threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Nov 07, 2007 | Janome Mini Compact
Sewing Machines Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
