Question about Fenix E05
Fenix E05 bulb
I have this torch for about 2 months, and it stopped working. it's not an issue at the level of the battery (as in empty battery), nor at the level of the contacts. my guess is it's in the top part that houses the bulb. anybody can suggest a way to open that part and try find a solution? thanks to all
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: I have a Fenix TK15 that doesn' light up. I have changed batteries, still no light
Hi marlyn engaling...
Sounds like you need to replace your bulb, it may be burned out.
Also check the switch and also make sure the spring in the back of the flashlight is touching the battery tightly to make good contact.
Bud
Posted on Sep 21, 2012
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
Can you open the switch end of fenix hl21?
the plastic will break and even if you do get access to that, the issue with the corrosion will still cause problems.
Nov 24, 2013 | Fenix Flashlights Black HL21 Fenix HL21...
Bud
Sep 18, 2012 | Fenix TK15
Fenix hp11 headlight
Hi, I have some experience with this unbekievable good headlight(when it works).
I had a hp10 what started to stop more and more.
After a while it wasn't going on.
5 years warrenty, so i got a new one, the new model.hp11
The main problem is the wire from battery case and the head led.
When there a litte damage inside this wire, light goes of not going on it selfs when it connecting again. After a while it will not work any more.
(if you have a welding station you fix it your self (battery case,can go open by unscrew the wire entrance.)
Chack battery case if the springs are all still connecting the battery.
If you put in one battery false on there is short cut and al sprigs get so hot they will shrink. And stay in that position..fix that your self or ring/ contact the shop you bought it.
There 5 year of garrantie.
wonderfull
Jul 25, 2012 | Fenix Camping, Backpacking & Hiking
Error Code E05 Canon MP258
Error Code E05 Canon MP258 may solve by the following steps.
1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
Sep 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Mid wash machine stops with display e05
Unfortunately there are different meanings for 'e05/F05' depending on the model of your washer. The majority state 'NTC' failure.
'NTC' stands for 'Negative Temperature Co-efficient' or water temperature thermostat to you and me!
One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a couple of boiling kettles into it. That can sometimes kick the device into correct action. It's worth a try anyway before having to call in the repair man ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 18, 2011 | Hoover Washing Machines
I have a 2000 jeep grand cherokee loredo. The engine has been rebuilt. Regular oil changes done. Has gas, air, & spark. While I was driving it just died. Gauges weren't coming up but battery was...
Vapor lock left in the 1960's
You can not use a vehicle with the gas cap off
& evap system open. Don't even try that stuff
Study OBD2 Systems on the internet
You need to stop with all the waiting & just explain
it all to a repair shop & get each issue taken care of.
If I had a vehicle that bulbs kept having an issue, i would
stop using it, before I got run into or a ticket & fix it
You could have alternator problems as well as
a failing fuel pump
Got lost to work on,several different things
Jun 10, 2011 | Jeep Grand Cherokee Cars & Trucks
Fenix E05 Logo
65 people viewed this question
Top Fenix Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Fenix Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
