My hi sense LCD flat screen.half left scorn is working fine but right half is only green white lines and box shapes flashing.how to fix it.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Check the flat cable connection [LDVS] cable, that connects T'Con board to LCD panel for any loose contact. Re-seat it once, and check. If it do not help you, the T'Con board, said above, is faulty and should be replaced. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Posted on Apr 25, 2013
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
42in Vizio TV
well i it the LCD you can try to fix if u have tec skill there are some IC in the flex cable the there
Jan 13, 2014 | Televison & Video
Lg 47lh40
Check its connection between LCD pane and T'con board for any loose contact.
Apr 28, 2013 | LG 47LH40 47 in. LCD HDTV
1 dg board, (stv 5v sense time out). ........ive
To pettinabatem
I am having a shutdown problem with a Panasonic TC-32LX50. Initially when pressing the on switch, you see for 1 second a right half white screen (the left side of the screen remains black) and the TV turns off and the LED flashes 1 time. I did a T-Con cable check (based on the half white screen) and indeed this went away. Got backlight (full screen and no half white screen anymore). But still the TV shuts down after 1 second and the Red front LED flashes one time. Since this code is also illustrating a "dg board, (stv 5v sense time out)" problem in this unit, I was wondering if indeed you have encountered a defective DG board with yours. I am enclining towards a defective Power supply board.
Jun 27, 2011 | Panasonic Televison & Video
Left half of my TV screen is completely white
That is only available to Sony authorized servicers. See esupport.sony.com
Jul 31, 2010 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
I have a 32in element flat screen had for couple of months now tonight there is a black box in the middle of my screen what should i do
I would like to know the same. We purchased ours on 10/25 and on 12/29 a black half moon shape showed up in the lower left hand side of the screen. Now the rightmost side of the screen is almost covered in black circles. There are also varying widths of lines going up and down on the right half of the screen.
We have tried contacting cusomer service and keep getting voicemail.
Nov 05, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Jan 28, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Only the left half works
You could try removing the ribbon cable directly under where the lines are from the X module and clean the cable and reinsert it. You could have a bad X Module if cleaning doesn't fix it.
Let me know if this helps.
Jul 29, 2008 | LG 32LX1D 32 in. LCD Television
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
