Question about Symbol LS2208 Handheld
LS2208 scanner unrecognized by my HP notebook
My HP notebook using Windows Vista doesnt recognized the LS2208 scanner thru usb port. It says "unrecognized usb device" when i plug the scanner thru usb... help.....
  • Anonymous Mar 22, 2014
    Scanner will not scan the laser is very dim
    Genius:
  • 2,985 Answers
It is not likely VISTA will run your scanner software as it is very old. However you could check program compatibility mode and set it to run as Win 95/8 Check compatibility in Start/Programs/Accessories or go to my Computer Windows Help[ and type compatibility in the search field But I don't think you will get far.
Posted on Aug 06, 2007
SOURCE:
My notebook computer only has USB plug and it does not has serial port plug (RS232). I bought a USB converter cable for the RS232 plug. The notebook computer reconciles the USB converter cable and not...
Tthe Capshare only works with XP or Windows 7 Ultimate which has a virtual XP inside it ( a retrofit for outdated software).. I will not work with VIsta.
Feb 13, 2011 | HP CapShare 920 Handheld Scanner
Dear sire I have symbol LS2208 handheld scanner (serial cable) but when connected in com port in a regular PC it do not power on .
you're going to either connect it to a com port that provides power, or get a different cable that allows you to connect an external power supply to it.
CBA-R01-S07PAR RS232 Cable assy, 50-14000-009R 220V PS,
or get a usb cable - program the scanner to USB, This will provide the power.
CBA-U01-S07ZAR-B
but only if you have an operating system that recognizes USB
Sep 23, 2010 | Symbol LS2208-7AZK0100S Handheld
LS2208 displays no light
If the scanner is on a USB extension, they can be underpowered and will show up in the device manager but not work. This device like to be connected to a USB cord no longer then 4 ft or so.
Feb 23, 2010 | Zebra LS2208 Handheld Barcode Scanner
I have an HP Scanjet G3010 that I am using with both XP and Vista. The problem is that sometimes it works fine and other times I get an error message that states the following "One of the USB devices...
This is usually caused by a faulty USB handshake. The two most common causes are bad contact (i.e. bad USB port or cable) and interference inside USB hubs, especially the externally powered ones.
You can (usually) solve the problem by disconnecting the cable, waiting for the USB disconnect sound, and reconnecting the cable.
The real solution of course is to correct the hardware problem (which might be as easy as using another USB port, or as difficult as having the scanner replaced -- even if usually the problem is external to the device).
Dec 05, 2009 | HP Office Equipment & Supplies
Canon Rebel XTi not recognized when plugged into usb
Vista is your problem. Solution...buy an inexpensive card reader to download your pics to a folder you create on your desktop. From there, you can send the pics to your photo editing software.
Oct 23, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
HP DIRECTOR NOT WORKING
the director will appear to not be working if the scanner is not installed and recognized by Windows. A scanner icon will appear on the desktop if it is recognized by Windows.
One likely reason it isn't being recognized is the power supply isn't putting out enough current, 1.25A, to force the correct signal level through the USB port. If the power supply is old, not plugged directly into the wall, or a substitute with the wrong current rating, the scanner will not send enough power through the USB port.
Jun 09, 2009 | HP ScanJet 2400 Flatbed Scanner
USB device not recognized
This solution worked for me when I got the USB device not recognized message:
http://www.infobarrel.com/USB_Port_Repair
It can be quite frustrating. I've heard that older computers are more likely to have the USB device not recognized message.
May 31, 2009 | Dell Inspiron 6400 Notebook
EXT HD UNRECOGNIZED BY LAPTOP
Which operating system are you using? Windows XP or Vista?
Here is the website that you can download the driver for your external harddrive.
http://support.wdc.com/product/download.asp?modelno=WD1600JB-00FUA0+WD+&x=1&y=11
Mar 26, 2009 | Western Digital External USB 2.0 80 GB...
LS2208 works - Keyboard does not
Check that the wedge is good. It is basically a hybrid spltter that powers both the scanner and the keyboard.
USB keyboard?
If so, you may want to go direct to either a serial port or a USB direct connection
Feb 24, 2009 | Symbol LS2208 Handheld
Symbol LS2208 Handheld Logo
996 people viewed this question
Top Symbol Computers & Internet Experts
Vish Iyer
Vish Iyer
Thomas F. Schneider
George Etukudo
George Etukudo
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
