Question about LG Electronic Window Air Conditioner
Lg 10000 btu ac wall unit
Hello, well the problem i am having with my ac unit is since yesterday i put it on energy saver as i do everyday but i notice that it wasent turning off when it was to cold, it was working fine before that, please if you could help me with that, thank you very much. Francisco
  • 1 more comment
  • francisco torres Aug 06, 2007
    hi thank you for your help, well it wont turn off at all even at night when its really cold i put it at 80 and it still wont turn off, i really think is a bad sensor because if i put it at 80 temp, it will run the same as if it was at 60, what can i do if its the sensor that is not working correct? please let me know, and thank you for all your help.
  • AMRK May 24, 2008
    Yes.
    Regardless of the temperature I set, the AC continues to run and the room gets colder and colder. I cleaned the filter on the front. Unit is about a year old, I have to manually turn the AC off and then on again to keep room cool....usually we like it at 72 to 74 degrees.
    AH
    Novelist:
  • 159 Answers
If you remove the front cover you should see a little sensor with a wire. you need to make sure it has not fallen off its bracket or came off form the evaporator. if it looks to be ok and mounted correctly, you may have a bad sensor and it is not able to tell the temp and not shut the unit down. also to on very hot and humid days even though you have it set to energy saver it senses it still needs to run. If you turn the thermostat up when its on the energy saver will it shut off? and if you do the same on the regular setting will the comressor shut off and the fan stay running? Let me know and I can go from there. Thanks
Posted on Aug 06, 2007
I am looking for0.8 tons a c of price 10000
This is a fix it site. check your local kijiji or craigslist.
Jan 06, 2015 | LG Window Ac Unit 18000 Btu, Energy Star...
My air conditioner will not heat
Try to talk spanish to it lol have to be more specific ac itself do not heat
Nov 26, 2013 | LG LW1512ERS 15,000 BTU Medium Window Air...
My Dometic AC on my travel trailer cools well but I cannot set the fan to stay on when the compressor cycles off. Can a different switch or board be installed to allow the fan to stay on?
An energy saver setting is what it sounds like. Turn off energy saver feature and fan should run 100% and compressor cycle on-off separately.If not familiar with energy saver setting .make sure it has one or not before disregarding this.
Feb 28, 2012 | Dometic Rooftop RV Air Conditioner
My airconditioner has been on energy saver for almost 2 days and will not come on what should be do
If this is a window or wall unit. Turn the Master ON/OFF Switch to OFF. Unplug the unit and wait 12-15 minutes. Then, plug the unit back in and turn the Master ON/OFF Switch to ON. Set the controls on anything except energy saver. If the unit then operates as it should, let it run for at least an hour before switching it to Energy Saver Mode. If that's the way you want to operate it. If it doesn't restart and run like it should or it shuts OFF on Energy Saver Mode, there is a problem with one of the setting sensors and needs to be replaced.
Also, while you have the unit unplugged, check the outlet to make sure it's still active. You can do this by plugging in a lamp. If the lamp doesn't work, the circuit breaker for that outlet has been tripped in your home's circuit breaker panel and needs to be reset. When you plug the AC unit back in and it trips the breaker again, there is an electrical short or overload in the AC Unit.
Please keep in mind everything I suggested is based on your AC being a 120 volt window or wall unit.
Hope this helps you solve the problem.
Apr 13, 2011 | GE Heating & Cooling
BTU of air conditioner?
Here are all the specs of the air conditioner whirlpool ACU102PK
Key Features Type Thru-Wall/Window Cooling Capacity 10000 BTU/hr Energy Efficiency Rating 8.5 EER Remote Control Without Remote Control Fan Speeds (Cooling) 2 Dimensions Width 25 in. Depth 20.5 in. Height 14.5 in.
Hope this helps you and Good Luck.
May 13, 2010 | Whirlpool ACU102PK Air Conditioner
Can you vent the Rinnai 551F vertically through ceiling?
This unit can be vented through the roof but requires a specialized flue system-do not use an existing flue connection. Call a contractor - have them check and see if the unit can be modified to a vertical flue- it will require the existing piping to be replaced--Not a job for a do-it yourselfer
Nov 01, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
WHAT DOES 12000BTUh MEAN OR REPRESENT IN AIRCONDIONING terMS? eg 12000 or 10000
I found this explanation which I certainly couldn't improve on.
The British thermal unit (BTU or Btu) is a traditional unit of energy. It is approximately the amount of energy needed to heat one pound of water one degree Fahrenheit. One Btu is equal to about 1.06 kilojoules. It is used in the power, steam generation, heating and air conditioning industries. In scientific contexts the BTU has largely been replaced by the SI unit of energy, the joule (J), though it may be used as a measure of agricultural energy production (BTU/kg). It is still used 'unofficially' in metric English-speaking countries (such as Canada, the United Kingdom), and remains the standard unit of classification for air conditioning units manufactured and sold in many non-English-speaking metric countries.
In North America, the term "BTU" is used to describe the heat value (energy content) of fuels, and also to describe the power of heating and cooling systems, such as furnaces, stoves, barbecue grills, and air conditioners. When used as a unit of power, BTU 'per hour' (BTU/h) is understood, though this is often abbreviated to just "BTU".
I located it at this site all credit for this info is:
http://en.wikipedia.org/wiki/British_thermal_unit
Hope this is what you need,
RSMITH972278
P.S. PLEASE RATE ME !
Oct 18, 2009 | Heating & Cooling
BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
LG Electronic Window Air Conditioner Logo
401 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Steve F
John Tripp
John Tripp
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
