What is E1 error on machine sgw2100
Dear sir, i have a super general washing machine having model sgw 6100 and it is not going to start as we have lost our mannual so we could not find the meaning of error. as it is showing EI and not going to start, could you please send me a soft copy for trouble shoot or guide how to solve the problem. thanks daud
huuum
  • 750 Answers
SOURCE: Wont start has error DE
Error displayed table_1.gif Solution
n_de.gif table_2.gif i_1.gif Close the door.
n_4e.gif table_2.gif i_1.gif Make sure the source water faucet is turned on.
i_1.gif Check the water pressure.
n_5e.gif table_2.gif i_1.gif Clean the debris filter.
i_1.gif Make sure the drainage hose is installed correctly.
n_ue.gif table_2.gif i_1.gif Laundry load is unbalanced; loosen any tangled laundry. If only one item of clothing needs
washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an "UE"
error message will be shown in the display window.
n_3e.gif table_2.gif i_1.gif Call after-sa
Posted on Dec 07, 2008
tunde007
  • 2382 Answers
SOURCE: Gd evng Sir. I am Krish.
Hi, in other Daewoo models E9 error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probably that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles and removing it should solve the problem....
Posted on Dec 09, 2010
  • 6277 Answers
SOURCE: Hi friends, I have Panasonic
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
  • 6277 Answers
SOURCE: My LG WD-85260NP model Front
LG's 'FE' stands for 'overFlow Error' which I strongly suspect means a service engineer's attention. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Aug 15, 2011
  • 6277 Answers
SOURCE: I want user's manual for Super general Washing
Unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
John C.
Posted on Oct 08, 2011
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
Error 2 super general washing machine
I have super general washing machine model is sgw 620 this machine coming error E5
Oct 04, 2016 | General Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Washing machine E1
    You have not included the make and model of your washer so that makes it pretty hard to answer for sure. A google search shows that several makes have an error code of E1 and it refers to a slow drain. Attached youtube video link is for a whirlpool washing machine and might help. If not repost with the make and model of your washer.
    Washer Repair Drain Pump Error F9E1 Maytag 2000 Series Whirlpool Duet...
    Aug 16, 2014 | Washing Machines
    SGW-7100 s
    No question there !!
    Aug 11, 2014 | Washing Machines
    How to used super general sgw 5800
    I do not know how to use Super General washing machine SGW 5800 I recently moved to a furnished apartment in Dubai I found this washing machine i could used it 1 time after many trails and after that i tried to operate it again but no hope. ...please help me
    Jun 23, 2014 | Washing Machines
    Super general washing machine (SGW 5800) front loader wont stop
    Do an extra long rinse with no load, make sure door sensor in pushed in properly, then module should sort out itself
    Apr 29, 2014 | Washing Machines
    E2 error code aw-8990st toshiba wash
    E21: Lid open
    E31: Load imbalance
    Hope this helps
    Jan 25, 2014 | Washing Machines
    Super general SGW7100 E1
    my washing machine super general sgw7100 has error E-62! how i solve this problem?
    Feb 19, 2013 | General Electric WHDSR209DWW Top Load...
    Super genral washing machine sgw 615 belt detail
    Could you please describe the problem you are having?
    Oct 17, 2012 | Washing Machines
    Washing Machines Logo
    76 people viewed this question
    Top Washing Machines Experts
