I restore Mitel icp 3300 and all passwords not working ?
I restore Mitel PBX icp 3300 10 , but all password not working ( root , system and admin ) i am tried many times to enter password i needful to open it . Can any body help me please ???
SOURCE: how can i restore a dell ****
Please use the Ultimate Boot CD - there is a program on that CD that can remove the admin and any other Windows passwords.
www.ultimatebootcd.com
If that helps, please donate something to that developer on the same UBCD website.
Posted on Apr 24, 2009
  • 3 Answers
SOURCE: mitel 5220 ip phone locked out ICP 10.0.0.135
Locked out generally means the phone is off the hook and there is no live call. Just press the X or cancel key, or pick up and hang up the phone.
Posted on Jun 24, 2009
SOURCE: we have a mitel 3300 connected to cisco CM thru siptrunk
can somebody help me we have a Sip connection between a mitel 3300 and Cisco callmanager only the conference call doesn't work who can help me out
Posted on Jul 10, 2009
ted1430
  • 339 Answers
SOURCE: i forgot the password and cannot access the web interface
Your phone has two passwords, administrative and http. If you lose http but still have administrative you can fix this through the web interface as your are trying. If both are lost then you will have to reset the phone to factory defaults by using TFTP to update the frimware. Note that this will result in you starting from scratch with your configuration.
Here is the SNOM wiki article containing directions for doing this:
http://kb.snom.com/kb/index.php?View=entry&CategoryID=44&EntryID=32
Posted on Jul 12, 2009
Douglessd
  • 284 Answers
SOURCE: says error after typing "admin" leaving password blank.Plz help.
Someone may have changed the password in the past.
There is no way to tell what it has been changed to.
You can try obvious ones like "admin" and "password"
But if you can't guess it you may have to do a factory reset.
This will reset the password and everything else.
It may be case sensitive username. Try Admin and admin.
with blank password. or Password, password.
Posted on Aug 19, 2009
How do I change the date and time on a Mitel Superset 4025 phone system?
The time has to be changed in the programming interface of the phone system itself. You cannot change the time from any set other than a 4150 or a super console 1000. These sets can only be used to change the time on a mitel sx200 or icp. This does not work on the 3300.
Oct 09, 2014 | Mitel Superset 4025 Corded Phone...
Employee quit work and we need to reset the password for the Mitel Superset 4025
This is a system manager finction. Whoever maintains your PBX and voice mail system has the ability to do this. Hope this helps.
Feb 12, 2014 | Mitel Superset 420 Corded Phone
How to change the time on Mitel 5212
The time is set from within the phone system and is sent out to all the display sets. You will have to log into the phone system and change it there. This is different on an SX200 ICP than it is on a 3300 ICP. But in either case you will have to know the IP address of the phone system as well as login credentials to it.
I suggest you contact your phone system vendor for specifics. Most sites I work with has a Point of Contact for the site that handles day to day maintenance on the phone system - such as name changes, button assignments and time changes.
Good Luck,
Mark
Mar 28, 2011 | Mitel 5212 IP Phone
Hi i am having a problem setting my password for the router
The default username and password for most routers is admin, administrator, or root for the username and blank (no password), admin, or root for the password. That should get you logged in, if you have set a username and password and cannot get into the configuration screens most routers have reset button by the ethernet ports that when held down for approx. 30 seconds will restore the router to factory settings.
Mar 21, 2011 | Computers & Internet
I need to change the time on my Mitel 5212 ip phone
The time on the phone is managed by the phone system. I suggest you contact the system administrator or system vendor.
The newer releases of the 3300 ICP, now known as MCD, can synchronize it's time. Older systems can't sync the time unless you have OPSMAN.
Nov 08, 2010 | Mitel 5212 IP Phone
Mitel 5020 holding
What is the problem with this? Are you referring to the Music on Hold? If so, what do you have for MOH? What phone system do you have? The 3300 ICP can have the music embedded into the programming. All other Mitel systems have to use an external source.
You should contact your vendor for assistance.
If you're referring to the hold time, you should contact your vendor to change it.
Dec 03, 2009 | Mitel 5020
Need installation/hook-up instructions for mitel 5220 IP phone
You will have to give more info on your setup. Need to program a Ext. in the phone system. Does the phone get DHCP off the network or are the phones hard coded.Need info on network?
May 11, 2009 | Mitel 5220 IP Phone
Phonebook on Mitel Superset 4025
It depends on your Mitel Telephone system.
If your system is an SX200 ICP ~ then going thru the Blue Superkey options the Mitel will let you change your own name.
But ~ if you have a 3300 ICP then the name change is only performed via the system programming.
Mar 26, 2009 | Mitel Superset 4025 Corded Phone...
Ip 5220 Mitel
You'll need to log into the voicemail server or PBX that hosts the VM and reset the passcode for each mailbox you're trying to access. If you have an embedded Mitel VM you can change the passcode by logging into the Admin mailbox then select option 2 to edit mailboxes, pick the mailbox to edit and follow the prompts until you have the option to change passcode
Jan 29, 2009 | Mitel 5220 IP Phone
5215 5220 and 5224
The Mitel IP phone downloads its firmware from the 3300 ICP on startup, You need to spesify what the phone is doing, ie does it start up at all or is the phone Dead,
If the phone does start it might have the wrong settings in the phone preventing it from finding the 3300 ICP, There is a Default to factory setting by interupting the phone on bootup.
Dec 07, 2007 | Mitel 5215 Corded Phone (50002817)
Computers & Internet Logo
204 people viewed this question
David Payne
David Payne
