Question about Nikon Coolpix L310
Battery exhausted FOR BATTERY LEAKAGE . WHAT SHOULD I DO? HOW CAN I CLEAN BATTERY SLOT
    Guru:
  • Nikon Expert
  • 362 Answers
A solution of baking soda and water will neutralize the battery acid. Use a Q-tip soaked in the solution to carefully clean the contacts. Do not allow the moisture to leak into the camera's interior. Once you have neutralized and removed as much of the acid as possible, carefully polish the electrical contacts. A clean pencil eraser should do the job, but you can also use a small piece of extra fine emery cloth to clean the contacts until they are bright and shiney.
Posted on Apr 23, 2014
New batteries and my minolta 7000 will not power up
Check for battery leakage on the springs n the battery compartment. That is the usual cause. You may have to disassemble the battery holder to clean it all out (use CLR to resolve the sludge and then clean it off).
Sep 30, 2014 | Photography
Battery leakage
tricky, I would suggest a cotton bud (Q tip) dipped in a mild soapy solution, and squeeze the excess water out to leave them damp, then gently wipe around the battery compartment. If any water should happen to get inside the compartment, dry with a dry bud, either way leave until completely dry, a few days somewhere warm. Battery leakage, if left can corrode the terminals. If your terminals are not rusty they should clean up fine. Try that
Jul 11, 2014 | Canon T50 Slr 35mm Film Camera
Film advance motor
This camera is powered by a 6-volt 2CR5 battery. Check the battery, look at the camera battery condition indicator. If it is all black the battery is fully charged. If it does not show all black or partially black remove the battery and test it with a battery tester. If the battery checks good then look inside the battery compartment making sure it is clean without any battery leakage. Again, if the battery and battery compartment are clean as they should be then it may need a CLA.
Mar 15, 2014 | Minolta Maxxum 7000 35mm SLR Camera
My emachines netbook doesn't charge past 42% anymore. There is no battery leakage, or problems with my netboook. What can I do to charge it all the way back to 100% ?
I would think it is quite likely to be an exhausted battery. They leak as they get nearer full charge and in time will fail completely.
Hope this explains it for you.
Feb 25, 2011 | eMachines eM250-1915 Netbook
Renewed batteries but still no life in camera.
Check and clean battery contacts for alkaline leakage or NiMh leakage on AA batteries.
Dec 04, 2010 | Kodak EasyShare C713 Digital Camera
Having a hard time getting the battery out - it seems stuck and i have to force it out with a tool. Will replacing the battery fix that problem?
hi, you are right sir. this battery sticking is due to bulging of the old battery. this happens due to ageing and over charging of battery. this kind of battery is very harmful for the camera. this may cause leakage of battery in the battery slot, which may lead to a big repair from the technician. sooner you replace the battery safer you will be. thank you sweet rascal
Oct 18, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
DSC-P72 only operates on AC power, not batteries
Check to see that the batteries have not leaked in the battery box. If they have clean out an leakage of the battery on the battery box contacts.
Jul 03, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
Exhaust gas reciculation flow
Below is a link to the EGR (exhaust gas reciculation) valve on your car.
http://www.chiltonlibrary.com/content/images/9115/images/91154p25.gif
Here are instructions on removal:
  • Disconnect the negative battery cable.
  • Unplug the electrical connector from the EET.
  • Detach the vacuum hose from the EET.
  • Remove the EGR valve mounting bolts, then remove the EGR valve and EET.
  • Remove and discard the old gaskets. Thoroughly clean the gasket mating surfaces and/or passages.
  • Check for any signs of leakage or cracked surfaces. Repair or replace as necessary
    Best of luck on your repair.
    Greg
  • May 30, 2009 | 1999 Plymouth Grand Voyager
    Maintenance
    OFF-ROAD VEHICLES - Initial Service: Check carburetor adjustment, engine idling speed and starter operation/adjust if necessary, Change engine oil/filter, Check clutch operation, Check wheel runout, spoke tightness and for damage, Check swingarm pivoting point for play, correct if necessary, Check steering bearings for play and steering for roughness, Check sidestand Torque all nuts, bolts and screws to spec, Clean or replace air filter, Check tires for damage, Check front and rear brake operation, fluid levels and for leakage, Check wear levels on brake pads, Check and adjust chain/sprockets, Road Test Motorcycle. EVERY 60 HOURS: Check fuel hoses for cracks or damage, Check spark plug condition. Clean, gap or replace if necessary, Check exhaust system for leakage, Check wheel bearings for looseness or damage, Check fork and shock for leakage or damage and smooth operation, Check battery terminals for looseness and corrosion. EVERY 120 HOURS: Check valve clearances, Clean spark arrester, Repack swingarm bearings, Replace fork oil, Replace brake fluid
    Nov 10, 2008 | 2005 Yamaha WR 250 F
    Nikon Coolpix L310 Logo
    81 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
