Question about Micro-Star H61M-E23 B3 - MSI H61M-E23 B3 Desktop Motherboard -
Motherboard msi h61m-e23 (b3)
Sir.... i have this system unit and motherboard is msi h61m-e23. switching on the system gave me an hour waiting the monitor to display but unfortunately nothing comes up. i already done basic troubleshooting like removing and replacing memory but still wont solved the problem.. hearing the beep code will also gave me nothing. any solution or suggestion is appreciated.. thanks in advance..
  • zhed Apr 26, 2013
    tried your suggestion but no luck for me...:(
  • 3,799 Answers
Try a different monitor, just to remove that from the equation. If that doesn't work then try an add on graphics card. it will save your computer.
Posted on Apr 25, 2013
Testimonial: "tried your suggestion but no luck for me...:("
MSI N1996 intel MOTHER DRIVER (AUDIO, VGA, LAN) DRIVERS
pls replace the motherboard's code from the following link which code is h61m-p20-g3 and relative os. or u directly download from http://au.msi.com with ur correct motherboard code which is printed on ur motherboard and correct os.
http://au.msi.com/product/mb/H61MP20_G3.html#/?div=Driver&os=XP%2032
Jul 07, 2014 | MSI PM8M-V Motherboard
Ga-h61m-s2v-b3 not coming on using power switch
I agree with Mike, but would like to add a couple of things. I had the same problem with a Gigabyte board (new install) and found that I had to change the CMOS battery. I put in a new batter, and "voila" it worked fine after that. Also, not knowing your level of experience, make sure the front panel connections are on correctly. Generally speaking, if you look at the lettering on the plastic ends that plug into the board pins on the front panel connector, the lettering should face the edge of the board and not be facing the middle of the board. That too has caused a similar sounding problem in the past. Other than these two potential solutions, more information is definitely needed.
Mar 20, 2014 | Gigabyte Motherboard Ga-H61M-s2P-B3 Core...
Processor cold
Did you mean the CPU was not operational? The motherboard failed to Boot? The power supply did not function? No post beep when you turned on the computer? Be more specific about your problem?
Jan 13, 2014 | Gigabyte Motherboard GA-H61M-S2P-B3 Core...
Missing network adapter
it happen to me also. simply its burned out. can be a lightin or a m/b malfunction. get a pci net adapter. cheap and easy.
Dec 02, 2013 | MSI H61M-E33 B3 LGA1155/ Intel H61 B3/...
How to recover from BAD UPDATE flash bios on MSI H61M-P21 B(3)
Hello here is the homepage:
http://www.msi.com/product/mb/H61M-P21--B3-.html#/?div=Overview
Something has gone wrong trough the update.
The bios update file on the usb disk could, have been damaged.
You need to contact a MSI dealer, they can help you with the problem.
You will probably need to bring the usb disk also.
Here should be a restore file, to make the mainboard running again.
Good luck
Mar 24, 2013 | Computers & Internet
H61m-p25B3 3 beep sounds what does that mean?
3 beeps is usually an issue with your memory modules. Take them out, make sure contacts are clean, reseat them well, make sure they are locked in and try again. If that does not work, make sure they are the correct type of memory for that motherboard and that if you have more than one module installed that they are the same type of memory. All of these little things matter when building a system. Here's an article that may help.
http://www.brighthub.com/computing/hardware/articles/82489.aspx
Jul 28, 2012 | MSI H61M-P25B3 - H61M-P25 B3 - Motherboard...
My monitor wont recieve any signal from my computer
sir your monitor's VGA cable is not fine replace it and it will work fine get a new VGA cable from market and replace it then it will work fine.
Thank you
Mar 31, 2012 | Think Computer Computers & Internet
I have upgraded to Windows 7 and also a new Gigabyte GA-H61M-D2-B3 Motherboard. 4GB DDR Ram I have plugged my Cambridge Soundworks SW320 in but I only get some sound, eg all music and back ground sound is...
Gigabyte GA-H61M-D2-B3 Motherboard supports 2/4/5.1/7.1-channel HD audio, whereas Cambridge Soundworks SW320 is 2.1 (only). Hence, the PC should be configured to provide 2.1 Channel output. The audio of your system may be configured to 2.1. So, please check the Realtec Audio sound manager/ configuration from the control panel or from tray (near clock) and set it to 2.1 (2 Channel Stereo Output).
Moreover, audio on your PC may be running on default HD Audio Drivers. So, you may also download/ install the latest drivers for Gigabyte GA-H61M-D2-B3 Motherboard.
(Refer to download section at the bottom of the page). After installing audio drivers, you would be able to configure the audio.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 13, 2011 | Creative Labs SoundWorks SW320 Computer...
Micro-Star H61M-E23 B3 - MSI H61M-E23 B3 Desktop Motherboard - Logo
222 people viewed this question
Top Micro-Star Computers & Internet Experts
David Payne
David Payne
Are you a Micro-Star Computer and Internet Expert? Answer questions, earn points and help others
