Question about Danby DPR2262 Top Freezer Refrigerator
Danby dpr2262w - How do I remove the drainage containers on back of unit?
I need to remove the drainage containers (the ones that stack vertically on the back of the unit) but it seems like I have to take apart several sections just to slip them out. Is there an easy way to do this? The item I'm calling the containers are listed as D5 in the dpr2262 user manual. Unfortunately, we didn't get back in time to change tanks and some meat went back and the containers were filled with nasty juice :(
4 Suggested Answers
SOURCE: wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Posted on Apr 30, 2009
imufo2
  • 3773 Answers
SOURCE: Our Danby DFF8850 is having
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 29, 2011
marvin6051
  • 3 Answers
SOURCE: Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Posted on Sep 17, 2012
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
My danby model dpac90061 plugs in and wont turn on
Hi There,
I have just spoken to one of our technicians and he said that if the there is a red blinking light that usually means that the bucket or drainage system is full. If that is not the issue, it could be a malfunction in the touch pad. If the issue is not the bucket, please contact our customer service department regarding repair. (1-800-26-Danby) We are available Monday to Friday from 8:30am to 4pm EST.
Thanks!
Jul 18, 2012 | Danby DPAC90061 Portable Air Conditioner
I just recently purchased an air conditioner and I need some help with the installation. In the booklet it says that if you want continuous drainage that you need to have the continuous drainage hose out...
The model you have has an evaporator feature, that normally evaporates the left over condensation. However, there are times that the humidity level may be to high to handle all of the left over condensation. In which case, the pan would need to be drained. In most instances, a plastic low sided container would suffice. But, if you run the AC unit in a continual mode, there's a good chance not all the left over condensation would be evaporated.That's what the hose is for. Not sure why there are 2 of them. Generally there's only one. Anyway, the unit also will shut down automatically, if the pan gets full and needs to be emptied. It will not run until it's emptied. But, I caution you not always rely on that. Anything can go wrong when you're not at home.
Hope this helped you understand how the unit operates. If you have any more questions, call Danby's Customer Support Dept. The 800 number is in your Owner's Manual. They're good folks and will do what's necessary to help you.
Jun 16, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
Ice collecting above drainage tube. I removed the ice, the drainage tube was not clogged. A fridge repairman said problems like this were sometimes caused by warm air coming up the tube and suggested to...
The draining tube / tubing somewhere has a gooseneck similar like the one under your kitchen sink. That is to prevent air from coming up the tube. The area above the draining tube is supposed to be kept ice-free either by the closeness of the defrost heater or it has itself a heater built in.
May 08, 2011 | Danby D1707W Refrigerator
Danby propane fridge model # dpr2262w-6. the freezer still works great but fridge portion does not . the fridge has a bad smell. the fridge is at a cabin and no service
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 24, 2010 | Danby DPR2262 Top Freezer Refrigerator
Danby DPR2262W fridge won't cool, freezer works great
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Aug 05, 2010 | Danby DPR2262 Top Freezer Refrigerator
Change drainage hose
Access is through middle of unit. 2 philleps head screws, lift slightly and and it comes right out.
Aug 26, 2009 | Frigidaire FEX831CS Top Load Stacked...
Danby add water cycle, water being pumped out.
The pump acts as the drain valve. It sounds like the pump check valve is not working and you will probably have to replace the entire pump. The pump is fairly easy to replace.
Verify that the outlet from the pump goes directly to the drain hose. If so, the only other thing you can do is remove the drain pump and disassemble it to see if something is stuck in there or something. However, this is a more advanced procedure so I would recommend against it. Replace the pump.
Sep 12, 2008 | Danby DWM99W Top Load Washer
We have a Danby fridge model #DPR2262W, bought about 4 years ago for our cottage that has no electricity. Yesterday an acrid smell came out of it and later in the evening the carbon monoxide detector went...
Thanks very much for your offer and your effort. After about another hour I got ahold of someone at the company who suggested some solutions, so I'll try them out. Thanks again.
Mildred
Jul 02, 2008 | Danby Refrigerators
Danby DPR2262 Top Freezer Refrigerator Logo
24 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
