Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Where is the model number on this dishwasher - Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
FDB1050remo Making a squeaking sound almost as if a belt slipping. Not overloaded and nothing rubbing on washer blades. My only guess is that it may be related to low water pressure. Is that possible?
please make this test and fix it. God bless you
Drain Pump
If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Circulation Pump
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller
If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly
If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller
The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor
If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve
The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 18, 2013 | Dishwashers
Tip
How to receive the best dishwasher repair help on FixYa
There are a couple of things that you should include in your dishwasher repair question when you ask it on FixYa.com
1. Model Number
The model number can be located on the model/serial number tag that is located on the dishwasher.
Make sure you get the full model number from this tag and not the model number from the owners manual.
The model number from the owners manual only includes the first few digits of the full model number because they include that owners manual with many similar models of dishwashers.
With the full model number I'm able to look up factory service manuals, tech sheets, wiring diagrams, factory service pointers and so much more.
2. Detailed description of the problem
At the very least give a brief description of the problem you are having with your dishwasher.
Descriptions like 'My dishwasher don't work' is not very helpful.
Describe what is not working. For example is the dishwasher not filling with water? Maybe the dishwasher is full of water but it will not pump the water out?
The more details you can give the better. Instead of saying 'The dishwasher will not pump the water out' you could go into more detail and say something like...
"My dishwasher starts ok and seems to run fine, but at the end of the cycle when I went to take the dishes out there was still about a inch of water left in the bottom. I also noticed the the dishes did not get very clean, especially the glasses in the top dish rack."
Following these couple tips can help you get a faster and more accurate reply to your dishwasher repair question.
on Aug 03, 2011 | Dishwashers
Wan't take on water after first rinse
see this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Whirlpool 24 in. DU1055XTPS Stainless...
Top draw is stuck on rinse / can't move push button to go on anything else
make this tests and fix it. God bless you
Dispenser Lever
If the dispenser is broken and doesn't open or close properly the dispenser lever might need to be replaced.
Detergent Dispenser Cover
If the detergent dispenser cover is broken and the detergent dispenser doesn't work, the dispenser assembly should be replaced.
Wax Motor Actuator
If the dispenser will not release the detergent the actuator connected between the wax motor and the dispenser might be broken. Check the wax motor actuator and replace it if necessary.
Detergent Container
If the dishwasher dispenser doesn't work the detergent container may need to be replaced.
Dispenser Lid
If the dispenser is broken and doesn't open or close properly the dispenser lid may have to be replaced.
Detergent Dispenser
If the dishwasher dispenser doesn't work the problem is often related to the release mechanism. If the problem is with the dispenser itself, it may be easier to replace the entire dispenser.
Dispenser Door Spring
If the dispenser is broken and doesn't open during the wash cycle the dispenser door spring may have to be replaced.
Dispenser Latch
If the dispenser is broken and doesn't open or close properly the dispenser door latch may have to be replaced.
Dispenser Door Pin
If the dispenser is broken and doesn't open or close properly the dispenser door pin may have to be replaced.
Dispenser Actuator
If the dispenser is broken and doesn't open or close properly the dispenser actuator may have to be replaced.
Dispenser
If the dispenser is broken and doesn't open or close properly the entire dispenser assembly may have to be replaced.
Wax Motor
There is an electrically powered device called a wax motor which opens the detergent dispenser. If the dispenser is broken and will not open to release the detergent, the wax motor might need to be replaced.
Bi-Metal
If the dishwasher dispenser doesn't work the bi-metal actuator might be burned out or defective. The bi-metal is a simple metal loop which acts as a latch for the dispenser door. As electricity is applied to the metal loop, the loop deforms and bends away from the latch, releasing it. If the bi-metal is burned out it won't deform or release the detergent door.
Dispenser Slide
If the dispenser is broken and doesn't open or close properly the dispenser slide may need to be replaced.
Dispenser Repair Kit
If the dispenser is broken this dispenser kit may need to be replaced.
Main Control Board
The main control board provides power to nearly every component of the dishwasher including the detergent dispenser. If the dispenser will not actuate the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Jul 24, 2013 | Fisher and Paykel DD605FD Stainless Steel...
Rotor wont spin
Thermal Fuse
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Door Switch
The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Door Latch
If the dishwasher does not start, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. You should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel
If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad
Timer
The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Jul 24, 2013 | Fisher and Paykel Dishwashers
Bosch shu43c02uc
test this steps and fix it. God bless you
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Jul 22, 2013 | Dishwashers
Ariston Dish Washer LSE620A
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
No power
test this steps and fix it.God bless you
Thermal Fuse
Door Switch
Door Latch
Main Control Board
Touchpad
Timer
Jul 22, 2013 | Westinghouse Dishwashers
How much salt do I put in ,,, and why won't it
follow this steps and fix it. God bless you
Dispenser Lever
Wax Motor Actuator
Detergent Container
Dispenser Lid
Detergent Dispenser
Dispenser Latch
Dispenser Door Pin
Dispenser Actuator
Dispenser
Wax Motor
Bi-Metal
Dispenser Slide
Main Control Board
Jul 08, 2013 | Dishwashers
I have a year old kitchen aid dishwasher and during fill cycle it makes a thumping noise. The dishwasher every 5 or 10 seconds shuts off fill cycle then turns back on which I think is what's causing...
Drain Pump
Circulation Pump
Drain Impeller
Wash Impeller
Water Inlet Valve
God bless you255fe28d-9cc9-4874-b381-9c9de59f3f75.jpgc98d91d6-ba21-42ff-b684-98f0b3e856c0.gif
May 24, 2013 | Dishwashers
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
