Question about Extreme Networks SUMMIT X460-48P POE-SWCH REQ PWR CORD - 16404 Ethernet Switch
Problem with inter vlan routing on summit x460 48p.
Vlan trunk on summit 24e2
Extreme uses tagged and I untagged instead of trunk/access, so it would look like this for a trunk:
conf vlan test add port gi1 tagged
(and of course you could put other VLAN's on this same port too since it's a trunk)
conf vlan user1 add port gi1 tagged
and this for handoff:
conf vlan lam test add port fa1 untagged
Feb 14, 2012 | Extreme Networks Summit 24e2 Networking...
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
Netgear FSM7352S - VLAN not connecting
Create the same VLAN on all the switches that will need this VLAN. All ports that link to another switch should have ALL VLAN's set to tagged.
This one VLAN should not have an IP address on any of your switches. This way it won't get routed by any of your users.
Apr 06, 2010 | NetGear ProSafe FSM7352S (0606449038880)...
Inter-vlan routing
Unfortunately, the 5224 is a Layer 2 switch. In order to route between VLANs, you need a Layer 3 device somewhere else on your network. In other words, either a true router, or a multi-homed PC acting as a router, or a true Layer 3 switch. The 5224 is incapable of routing within itself. Sorry!!
Nov 09, 2009 | Computers & Internet
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
How to create vlan in nortol 3510 L3 switch
You would need to trunk the VLANS to the router and create sub
interfaces and then, create access lists applied to
the interfaces to control inter vlan communication. I hope this helps,
Router interfaces something like this, may not work on all versions of
IOS:
interface FastEthernet0/0
no ip address
speed 100
full-duplex
interface FastEthernet0/0.1
description VLAN1_Servers
encapsulation dot1Q 1 native
ip address 192.168.1.1 255.255.255.0
interface FastEthernet0/0.2
description VLAN2_QA
encapsulation dot1Q 2
ip address 192.168.2.1 255.255.255.0
interface FastEthernet0/0.3
description VLAN3_DEV
encapsulation dot1Q 3
ip address 192.168.3.1 255.255.255.0
interface FastEthernet0/0.4
description VLAN4_FIN
encapsulation dot1Q 4
ip address 192.168.4.1 255.255.255.0
Aug 01, 2009 | Nortel Enet Routing Switch 3510-24T Incl...
Sending DHCP request across diffrent vlans
Hmm... on your DHCP server, try setting the "default router" IP for each pool to be the VLAN ID on the switch.
scope 172.16.0.0 /24
router 172.16.0.1
scope 10.20.8.0 /22
router 10.20.8.1
I think the DHCP replies aren't going back where they should. I've never done this without a router doing all the DHCP, but it does work and i've done it many times. Your config looks spot on for the switch.
Feb 01, 2009 | Cisco Catalyst 3750E-48PD
Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
Oct 28, 2008 | 3Com 4500 24-Port Ethernet Switch
Inter Vlan routing
Just For InterVLAN routing, Mark (enable) administration Access for ALL VLAN :P
Sep 18, 2007 | Computers & Internet
Extreme Networks SUMMIT X460-48P POE-SWCH REQ PWR CORD - 16404 Ethernet Switch Logo
96 people viewed this question
Top Extreme Networks Computers & Internet Experts
David Payne
David Payne
Are you an Extreme Networks Computer and Internet Expert? Answer questions, earn points and help others
