I had this same problem and I found that the Data Link Connector is located below the dash board, but on the Canadian model I own, it has a white connector right below the fuse block area which required me to remove the lower plastic panel to gain access ( as per the haynes manual you need a OBD-11 SCAN TOOL TO ACCESS INFO.
It should be under the drivers side dash board. 1/2in x 1in black connector.
SOURCE: 2002 Nissan Xterra
you will have to remove the door panel on the inside and if you cant see the retaining bolts there should be a triagle shaped piece of plastic covering the bolts. if this helps please rate joe
SOURCE: parking lights nissan 2002 xterra
Open the back lift door. Inside next to the lights there are screws that need to be removed before you can get the whole parking light off. After you get the screws out, you will have to force the whole plastic light cover to get to the burn out light. Once you get the whole light out, replace the bulb and follow the process in reverse.
SOURCE: 2002 Nissan Xterra. Do I need a replacement key
the hardware shop are totally correct dealer only or a specialised auto locksmith
SOURCE: Excessive fuel cosumption in my 2002 nissan Xterra
need to have system checked to get a trouble code for light being on frist
Testimonial: "Yes very helpful"
SOURCE: Does my 2004 Nissan Xterra
Yes it does. Actually it talks in OBD2. The com port is located under the dash on the driver side.
