I have a samsung toploader dc68/20092c and it takes 6-8 hours for the entire process to finish
I am facing problem with the washing machine. it keeps stopping at intervals and takes 5-6 hours to finish the process although the timer says 30 mins
  • 1294 Answers
SOURCE: Washing time & quality
Look for wash cycles in your users'manual. It is best the read the manual well before operation.
Posted on Apr 11, 2007
SOURCE: long wash cycles
WHEN YOU WASH IS THE WATER HOT ENOUGH IN A REASONABLE TIME? ALSO DOES THE WASHER SENCE THE AMOUNT OF SOAP THATS IN THE TUB. IT COULD BE GIVING ADDITIONAL RINCES TO REDUCE THE SOAP CONTENT.(TRY WITH NO SOAP IN SYSTEM AND SEE IF TIME IS SHORTER)
Posted on Sep 18, 2007
SOURCE: WCVH6800J GE Front loader timer keeps resetting
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
Posted on Jan 16, 2009
SOURCE: When the timer gets down to 1 minute left and the
The timer is only an estimate. pull the botttom cover of the front of the machine. There is a cleanout on the water pump, if its clogged it could be the cause of your timer taking so long
Posted on Jun 27, 2009
  • 228 Answers
SOURCE: Bosch Classixx 6 - tried washing a load on easy
i have checked all my tech info and error codes only go to f 12!! never had f 17 but based on description sounds like either flow sensor or inlet valve failure will need service tech to sort out but if either of these will not be expensive.
Posted on Nov 13, 2009
My moms washer is taking 3 hours to complete a 40 degree wash, what could be causing this
it sounds like the program/timer is on its way out ( it should click down the minuets then stop ) try another setting that you know will only take 30 mins or so and see if it takes longer. if it dose then program/timer is the problem ( the board behind the settings dile )
Apr 23, 2015 | Washing Machines
Machine starts to fill with water, then stops and drains water. This process continues over and over, never moving onto a cycle. I have tried resetting and unplugging at the wall to reset but no luck
sounds like a bad control board issue or timer. would say the water pressure switch but that only tells it went to go into wash cycle but not start the drain process? since its going to drain cycle b4 washing I say timer sending wriong signal
Feb 23, 2015 | Washing Machines
WHY AREMY POWER BUTTON NOT COME ON WHEN PRESS
www.samsung.com/in/consumer/.../washing-machin...
www.samsung.com/in/info/contactus.html
Sep 08, 2014 | Washing Machines
My bosch classix 2100 washing machine takes 3 hours to finish a 30 degree wash.is this normal?
If it gets stuck on 1 minute for a long time, it is possibly the heating element which needs replacing. They can get covered in scale in hard water areas and stop working. Replacing the heating element in my Bosch Logixx solved the problem.
Sep 27, 2013 | Bosch Washing Machines
Washed a small bath rug in the machine. The piece of rug said it was washing machine safe. The rug broke apart as I was washing it and now the washing maching will not drain. I have to open the bottom...
This becomes a long drawn out process in which you have to remove the pump and the entire drain line and wash all the backing out of the machine also you have to remove the lines that go from the tub to the pump as well and even after you finish cleaning out the drain system you still will have more pieces stuck inside the tub area that you have to clean out as well. Easiest way take the machine outside or to an area you can use a hose on the unit where after you disassemble the entire pump area that you can wash the tub out of all the small pieces of the rug backing I had the unfortunate repair of doing this to someones rubber backed rug cept it took all the rubber off the back of the rug. It took about 3 hours with hooking and rehooking the drain lines and unclogging them over and over due to this unit I was working on was in a basement and no access to a hose If you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue helping others in similar situations in the future Thanks again Rick
p.s do this repair yourself a repair technician would charge about 200 to repair the unit due to the amount of time
Apr 28, 2011 | Samsung Washing Machines
Samsung Wf8804RP washing machine
hello - my door won't unlock at end of cycle on Samsung wf8804rp - its finished the cycle and the clothes just need taking out but the padlock is flashing and door won't open, I have tried turning it off for and hour and also doing a drain and spin but didn't work , many thanks
Feb 09, 2011 | Washing Machines
My kenmore stacked washer/dryer has a wash cycle that can last for 12 hours. it will ultimately finish and clothes will be cleaned properly but it takes long breaks during the cycle.
The time it takes to do a cycle is determined by the washing machine timer. That is driven by a clock motor. This is an older machine so what is happening is that the motor on the timer is stopping and starting. A replacement timer is sold only as a complete assembly. I'm fairly sure you washing machine does the best job in the world in cleaning cloths.
Hope this helps,
Best,
Mark
Dec 30, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
