Question about Ricoh Aficio Mpc3000 Color Copier With Printer/scanner/fax/finisher
Ricoh sc 565 - Ricoh Aficio Mpc3000 Color Copier With Printer/scanner/fax/finisher
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press 1 , 0 , 7
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Error sc 565 mp c2030
Hi
The first thing I tend to do with any fault on a computer or related hardware, is to turn it off, unplug it from the power supply, turn off and unplug the rest of the system components. Wait for a few minutes, plug the equipment back in and turn all components on and then reboot the computer. After this I start to look elsewhere for fault diagnosis and repair.
In your case I found a list of codes for your machine here:
Error Codes Ricoh Aficio MPC2030
Here you can view the specific codes by using the drop down menu in the middle of the page. You can also change the make & model of machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 31, 2014 | Ricoh Office Equipment & Supplies
Error sc 551
Replace both the thermistors and reset SC code
Sep 05, 2014 | Gestetner Office Equipment & Supplies
What is sc 565 on a sp c820
SC565
*Heat lamp consecutive on error
- Broken main fuser connection
- Check HR thermistors
- Heat roller lamp defective
- Power Supply defective
May 10, 2014 | Ricoh Aficio SP C820DN Laser Printer
Error code SC 565 Ricoh MP 2550
SC565
*Heat lamp consecutive on error - Broken main fuser connection
*Heat lamp consecutive on error - Check HR thermistors with SP1-106 001 (ctr) and 002 (ends)
*Heat lamp consecutive on error - Heat roller lamp defective
*Heat lamp consecutive on error - Power Supply defective
Mar 11, 2014 | Ricoh Aficio 2022 All-In-One Laser Printer
Sc 395 ricoh aficio 3045
fix copier is a youtube channel
fixing error in videos
this is a video see you how to fix sc 395
https://www.youtube.com/watch?v=cI6o6mYOqow
Jul 05, 2012 | Ricoh Office Equipment & Supplies
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh Aficio Mpc3000 Color Copier With Printer/scanner/fax/finisher Logo
65 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
