Question about Home
What is a good way to set out the decorative plates on a built into the wall plate display rack?
    New Friend:
  • 32 Answers
How to fix robertshaw thermostat display after changing batteries?
How To Replace Thermostat Batteries - YouTube
? 1:46
www.youtube.com/watch?v=QFd5jGL6vpM
May 10, 2012 - Uploaded by KungFuMaintenance Kung Fu Maintenance demonstrates how to change out thebatteries on most digital air conditioner and heater ..
Sep 19, 2015 | Robertshaw Thermostat Accessories 9010-1...
How do you make decorative plates at home?
found this online. not the fanciest but looks cute and would be nice decoration for the kitchen. http://www.moneysavingqueen.com/July-2012/How-To-Make-Your-Own-Decorative-Plates/
Jan 10, 2013 | Home
What is a wall mounted wine rack?
Wall mounted wine racks are the ones who can be place on the wall and they can be made out of different materials. The wall mounted wine racks are usually used for decoration and not for wine storage.
Aug 13, 2012 | Furniture
I have 3 door knobs on outside doors that are loose and need to be tightened. the knobs have come completely off sometimes when we go out the doors. how do I tighten the knobs so they are not loose?
On the inside side of the door knob, there is a decorative plate. Depending on which model door knobs you have, it is held on with a "set-screw" that might require an allen-wrench (looks like an 8-sided tool; usually in an L-shape), or just simply a screw driver, to loosen and remove it. Once you take the decorative plate off, there will be two very obvious screws that hold both sides (inside and outside) of the door knob together. Tighten these screws to tighten your knobs, then put the decorative plates back on again.
Feb 27, 2011 | Kwikset Professional Door Lock...
My standard size dinner plates are too tall, the rotating part is catching the plates
Some machines have height adjustable top shelf.
Should be couple of clips on side of rack to raise / lower.
Other than that you will have to get smaller dinner plates.
Please dont forget to vote this answer was helpful
Many thanks
Feb 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
I need an electro-mechanical timer for decorator plate. Intermatic E1343 is no longer available.
http://www.lutron.com/Products/StandAloneControls/Timers/MaestroTimer/Pages/Overview.aspx
Lutron makes a decorator plate countdown timer
http://waterheatertimer.org/Programmable.html
This page shows electro-mechanical dial-type timers, and it shows digital programmable timers.
The electro-menchanical dial-type do not use a Deco plate.
Instead each timer has it's own plate.
Now Paragon makes a multi-gang timer
http://waterheatertimer.org/images/Paragon-wall-box-300.jpg
http://midlightelectric.com/firex/acatalog/FIREXPARAGONROBERTSHAW_WB103.html
If you need more assistance, add a comment
Nov 04, 2010 | TORK 711A 24 Hr InWall Electromechanical...
The holder has fallen off the wall. There appears to be two screws, one that fits into the back of the centre of the wall plate and a small one that fits into the side of the wall plate. I don't think...
Hello Alicia
Most often the wall plate will screw to the wall and then there is a set screw (usually an allen key) to tighten the fixture onto the wall plate. If it is the wall plate that won't stay on the wall then your screw holes are probably stripped. An easy way to fix this is to fill the hole with a wood glue filler available at your local hardware store. Use toothpicks to jam the filler into the hole. You can also use white wood glue and jam glue and toothpicks into the hole. Let it dry overnight and the next day you will be able to screw the plate back onto the wall. If the fixture is falling off the wall plate then the set screw is not being tightened hard enough against the plate to hold it onto the wall. Good luck with the repair.
Jul 17, 2010 | Sonia GENOA COLLECTION TOILET ROLL HOLDER...
Top rack in Kenmore ultrawash not being cleaned
Check to make sure the upper wash arm is not plugged with debris. All Plates on the bottom rack and bowls on the top. Position the arm at 12 o'clock and check at the end of the cycle to see if it has moved positions.
Jan 20, 2009 | Kenmore 15899 Built-in Dishwasher
Home Logo
780 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
