Question about Toshiba E Studio 2830c 3500c 3510c Copier Drum Kit
C449 error code - Toshiba E Studio 2830c 3500c 3510c Copier Drum Kit
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
C449 error code in toshiba e studio 2540c
error C 449 Heater lamp abnormality after abnormality judgment (temperature abnormality at high temperature)
first of all just reset error with simulation may just malfunction error procedure for rest error for heater related.
turn copier off
hold down 0 & 8 while turning it on power switch
then press digit numbers 4 0 0 then press start key
then 0 key and set
Jul 26, 2014 | Toshiba e-Studio 2540C Multifunction Color...
Erorr code 4003 zebra zxb8
Error Code 4001
System error code 4001 means "The local WINS cannot be deleted." This error code may also display as "ERROR_CAN_NOT_DEL_LOCAL_WINS" or as the value 0xFA1.
Error Code 4002
System error code 4002 means "The importation from the file failed." This error code may also display as "ERROR_STATIC_INIT" or as the value 0xFA2.
Error Code 4003
System error code 4003 means "The backup failed. Was a full backup done before?" This error code may also display as "ERROR_INC_BACKUP" or as the value 0xFA3.
Error Code 4004
System error code 4004 means "The backup failed. Check the directory to which you are backing the database." This error code may also display as "ERROR_FULL_BACKUP" or as the value 0xFA4.
Error Code 4005
System error code 4005 means "The name does not exist in the WINS database." This error code may also display as "ERROR_REC_NON_EXISTENT" or as the value 0xFA5.
Error Code 4006
System error code 4006 means "Replication with a nonconfigured partner is not allowed." This error code may also display as "ERROR_RPL_NOT_ALLOWED" or as the value 0xFA6.
System Error Codes
Sep 15, 2013 | Zebra ZXP Series 8 Thermal Card Printer
My E-Studio Toshiba- 720 giving error c449 after starting please help as soon as possible
The error code C449 relates to your fuser, and it signifies that it is overheating. To identify the exact issue you would have to check all of the thermistors for the fuser assembly, the heater itself, as well as the LGC board. Please note that unless you have the training, experience, and proper tools I would not advise trying these procedures. As you are dealing with the fuser you can injure yourself or damage the unit if the proper safety precautions are not followed. Contact your local Toshiba repair center and arrange for a repair tech to do them. These are the detailed steps to follow:
1) Check to ensure that your power voltage is normal. During operation of the unit your voltage should not be more than +/- 10% of normal.
2) Check the thermistors to ensure all connections are good, that the front and rear thermistors are in contact with the fuser roller so that they are able to detect correct temperatures. Also check to ensure the there connections are still holding correctly.
3) Check the heater itself to ensure that the coil is not broken, that the connections on the coil are still intact, and that the thermostat is not blown.
4) Ensure that all heater connections to the control board, especially the AC input connector and the LGC I/F connectors CN455 , are still good.
5) Check to ensure that the IH control board has no abnormalities such as burnt or melted components.
6) Check the LGC board to ensure all connectors, especially CN332 and CN334, are still connected. Also check to ensure the conductor pattern is not short or open circuited. If necessary replace the LGC board.
Beyond those steps you would have to clear the status counter. To do so you would have to follow the procedures outlined in the service manual. You can either purchase the manual online if you are capable of repairing the unit yourself, or have your local Toshiba repair shop send out a tech.
May 15, 2011 | Office Equipment & Supplies
I have a blown power supply board for my Samsung SP5207HR Model EX5207 Version 1 rear projection televison. I trying to locate the following parts to repair it: 1 schematic for Samsung SP5207HR ...
The components that you require will be freely available but a stockist will need to know what they are, The transistor will be, for example 2SD1308Q the diode maybe a 1N4007 and capacitor say 33nF. To find the values, look on the component and it will be printed on it along with the manufacturer's idents and date codes etc.
Hope that helps you get a result.
Nov 17, 2010 | Samsung Televison & Video
Pop smoke and blurred screen. Found burn spot on botom of PC board under what appears to be the high voltage power supply. Looks like a charcoaled capacitor and maybe a diode. Have not tested the diode...
jdowell1,
The easiest solution would be to go to http://www.servicemanuals.net and purchase a downloadable service manual for about $16 US. If you plan on working on this unit in the future it should more than pay for itself. The manual would have the values of the components and much more valuble information.
Thanks for using FixYa and for the generous rating.
hardrocko
Aug 05, 2010 | Samsung HCN4727W 47" Rear Projection...
Component failure
what model you have and what brand?
Jun 12, 2009 | Televison & Video
Toshiba 40h80 picture problem
replace c449 and also the damper diode
Nov 19, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba E Studio 2830c 3500c 3510c Copier Drum Kit Logo
22 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
