Question about Tools & Hardware - Others
Rapid workline R53 ergonomic staple gun suddenly wont fire
Was working fine. Needed refill with staples. Worked for another while and then suddenly wouldnt fire Seems as if the staples are not being propelled forward. ANy ideas?
5 Suggested Answers
SOURCE: stanley sharp shooter tr110 staple
Are you loading it correctly? It took me awhile to figure it out myself. When you pull the clip out I was convinced you have to load them in there above where that black spring is on the slide lock that you pull out (as they seem to fit there) but no, you do have to turn it upside down to where the place where the staples shoot out is facing you and then load the staples into that space that you now see in front of you by placing the staples in upside down (pointy ends facing you). Then just slide the slide lock back over the staples you just placed in. I had to push down and then up on the clip to lock mine in all the way but some might lock in on their own (not sure). It should work fine from there.
Posted on Nov 14, 2011
SOURCE: refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Posted on Dec 05, 2008
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Posted on Aug 27, 2008
  • 384 Answers
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Posted on Jul 07, 2009
How do I put back together a Rapid R453 Ergonomic staple gun
Contact Rapid directly to request an assembly diagram for model R453.
Apr 05, 2018 | Tools & Hardware - Others
What.size staples needed for arrow fastener ct50
Product description
Product description
2750-1378 Features: -Revolutionary design with ergonomic handling.-Easy release drop in loading channel for staples.-Battery contains an easy to read LED charge meter.-Built-in safety switch prevents accidental firing.-Adjustable staple drive with depth of drive dial.-Light weight design for prolonged stapling tasks.-Can use T50 type 1/4'' staples (2750-0719), T50 type 5/4'' Monel staples, T50 type 5/16'' staples, T50 type 5/16'' Monel staples, T50 type 3/8'' staples, T50 type 3/8'' Monel staples, T50 type 1/2'' staples, T50 1/2'' Monel staples, T50 type 9/16''.-staples, and T50 type 17/32'' Ceiltile staples. Includes: -Kit includes case, charger, and tool. Specifications: -10.8 volts.
staples needed for arrow fastener ct50 Google Search
Jan 11, 2018 | Arrow Tools & Hardware - Others
My gun fires four or five staples all a once--is there an adjustment. with shooting so many staples at once then they do not go in all the way
  • This may or may not help, but I have one that was doing the same (as many as five at one trigger pull). I gave it the little WD40 and it still did the same. Then, I thought maybe it was the effect of not being used for a while. I proceeded to pull the trigger several hundred times (you can do this without staples loaded) and now, mine works fine. Seems to have helped.
Sep 16, 2014 | Electric Stanley Tre500 Staple Gun /...
My stanley tre500 shoots like a semi automatic weapon. Is it adjustable? Thanks Nancy
Hi Nancy,
Do you mean it rapid fires, or do you mean fires the staples to deep?
If it fires too deep, the adjustment for that is on the back of the gun. The + and - give more/less depth. Adjust it towards the - direction to get the brad/staple to no penetrate as far.
Thanks,
Handie Andie
Jun 16, 2011 | Electric Stanley Tre500 Staple Gun /...
Cannot find staples for this staple gun. The model I have just says PowerShot on the sides. I purchased some Black & Decker PowerShot heavy duty Staples for the gun but I cannot find anyway to get...
The ones you have are T-18 I believe
Fires 6 sizes of T50 type staples and drives 9/16 In. brad nails. Visual refill window and easy load chamber. Comfort grip.
•Uses Staples: PowerShot Staples, 97-010, 97-011, 97-012, 97-013, 97-014, 97-015, 97-030, 9/16 In.
•Brad nails
•Ceiltile 17/32 In., 9/16 In.
•T50 type staples, 505TML, 506TML, 508TML, 509, 50CT, 506SS, 504M, 505M, 506M, 508M, 509M, 504, 505, 506, 508, 509
•MFG Brand Name : Arrow Fastener
•MFG Model # : 5700
•MFG Part # : 5700
Aug 13, 2010 | Black & Decker 5700 Powershot Forward...
Arrow Fastener Co./Electric Staple Gun - ETF50BN
First make sure no staple is jammed between the hammer and the anvil or plunger and you might also try to spay with pb blaster or wd 40 and pull yhe trigger several times very rapidly and see if this will free plunger , does work to free sometimes
Jan 22, 2009 | Arrow T50P ARROW STAPLE GUN
Bostich nail gun plumger not retracting
spay with pb blaster while rapid firing gun into a piece of junk material , once free oil with a small amount of hold or sewing machine oil and then oil after each use
Nov 27, 2008 | Heavy Duty Stanley Bostich Heavy-duty...
Staple gun support
Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
Tools & Hardware - Others Logo
819 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
