Question about Whirlpool Dishwashers
Adp 7620 Hi, my dishwasher starts, the green lamp blink 11 times, then it pump in water and then the water gets out and then nothing. What can i do?
SOURCE: flashing light
I had this problem at home too, it turned out to be a kink in the water outlet pipe. I straightened out the kink in the pipe, put duct tale around it to strenghten it and the dishwasher has been working perfectly since.
Posted on Sep 22, 2008
SOURCE: my dishwasher model adp 941 won't start - start led flashes
exactly the same problem today with an AD9520
Don't know the cause but from reading other posts re dishwasher problems I tried holding start but on for 5 - 10 seconds and it seemed to clear the symptoms at least. It ran for a short while and stopped but the flashing had stopped and I could start a wash cycle which is now running!
Posted on Dec 14, 2008
SOURCE: Dishwasher (Whirlpool ADP 952) not working
I have a whirlpool ADP 952 and the start button is flashing and it won't work
Posted on Aug 06, 2009
  • 69 Answers
SOURCE: dishwasher adp 4601 when switched on the pump
The number of flashes indicates the fault. Reset machine by holding down the start button for 3 secs, then start a new cycle. If fault reoccurs, the number of flashes indicates fault eg 3 flashes, stop, 3 flashes stop, indicates F3 fault.
Faults listed below- advice on repair depends on which fault your machine is indicating, but may give you an idea of what to look for
1flash=NTC (temperature sensor) break- NTC outside normal range.
2flash=water leakage-float switch in base activated.
3flash=heating fault(check element.NTC,control board).
4flash=drain error-blockage in pump or drain system,or faulty water indicator switch.
6flash=water inlet fault-check inlet valve, check inlet hose not kinked
7flash=flow meter failure (flow meter measures water intake volume-large plastic weir located on left hand side of machine-reomve side panel to access)
These a most common faults, but further advice on repair requires counting flashes when fault occurs.
Posted on Aug 09, 2009
SOURCE: DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Posted on Feb 12, 2011
How to reset Whirlpool dishwasher ADP 6342; it stopped working and cancel button is blinking 8 times
F8 failure (slow/no draining)
In a consumer cycle, the appliance is indicating F8 E1 (slow/no draining). This is because of wrong signals from the circulation pump read by the control board and interpreted as "water present", when there is no water. During draining (and in fact, there is no water), the failure occurs.
1. Check if drain hose is not closed/clogged
2. Drain pump faulty, harness or wiring faulty, control board faulty
3. If machine is equipped with OWl, issue might be caused by damaged or dirty OWl. Clean the sensor lenses then , if issue is not solved, replace OWI (optical water indicator).
Dado
Jun 14, 2014 | Whirlpool GU2400XTP Built-in Dishwasher
Whirpool adp 2415
try turning off the power to the dishwasher for about 20mins then turn the power back on. sometimes this will reset the unit
May 21, 2014 | Whirlpool Dishwashers
I have a whirlpool gold quiet partner III Black dishwasher. All of a sudden it stopped working. I push the accusense button and start the cycle for washing, it looks like everything is working normally, I...
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or High Temp Wash-Heated Dry-High Temp Wash-Heated Dry . Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
ADP 4502/5 not working,not draining water,start
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jul 13, 2009 | Dishwashers
My dishwasher model adp 941 won't start - start led flashes
Dec 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Flashes 8 times ADP 5340
Again Pressed the main button for about 15 sec that did reset the fault
larf
Apr 20, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
Mar 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher almost fixed but won't pump water
Could be the motor is stuck. This is a common problem in dishwashers. With the power turned off, open the front kick panel and turn the motor a couple of times by hand. Then turn on the power and run the drain cycle to see if the motor drains properly.
Aug 21, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Ultra Wash Quiet Guard 3 problem
Thanks Munkee,
I started having this problem, blinking green light,  three days ago with my Kenmore QG3 and finally was tired of not being able to use my dishwasher. I've had it for three years with no problems until 3 days ago. You solution, use of commands, really helped and no money wasted on tech assistance. Thanks again!!
Aug 20, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
