Question about Sanyo HT28745 28" TV
Reset sanyo tv no remote - Sanyo HT28745 28" TV
10yr old Sanyo tv working fine then "mute"flashed on screen,tv went mute and wouldn't respond although everything else works normally.Not a flat panel-
try reseting the tv and remote.....unplug tv from the wall plug for 5 mins. then remove batteries from remote.....from left to right at the top of remote hit all the buttons on remote then put batteries back in try that......
Jan 16, 2016 | Sanyo Televison & Video
Where is the reset button?
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... how do i reset my sanyo flat screen television?
Dec 26, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV ... video tutorial television flat-screen model # kdl ln lt lnt hp ht LINK for TV boards & Parts ... 1. soft reset - is just turning tv off & back on ..... the source by using the on/off button on the side panel, remote does not work.
Dec 29, 2015 | Sanyo Televison & Video
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
May 21, 2009
Nov 29, 2015 | Sanyo DS31520 31" TV
I have a Sanyo DS27910 Flat Screen that is stuck on Video 1. My remote was lost in a move. I downloaded the manual but there does not appear to be a physical reset. Can you help me resolve this...
You can purchase the original remote for $20.99 base price.
http://www.replacementremotes.com/SANYO/Buy-FXRG-6450459313-TV-Remote-Control.html
Jun 10, 2011 | Sanyo DS27910 27" TV
Factory reset
in thid you have reset you tv with help of tv remote . this syestem is used because while seeing at night some oerson sleeps. so he set timer after which the tv gets turned off. to solve this you have to go in menu and you to search for a tinner or sleep option it can be directly on your tvv remote
Jan 30, 2010 | Sanyo DS24425 24" TV
My tv is stuck on the blue screen .
Go push menu button on the front of tv or the right side.Pick the video out,or tv.Or buy a remote.Website 1-800-Remotes factory Original.For the original remote.
Dec 18, 2009 | Sanyo DS27510 27" TV
No remote
just buy universal remote. or disconect the tv
for 10 minutes and then pluging back
Aug 14, 2009 | Sanyo DS13204 TV
Sanyo DS31520 TV
I am relentless when it comes to problems like this. I had the same problem with my TV being stuck in video mode. I found out that there is a reset button......It's on the @*&#^&^ original remote!!!!! So I tried programming my Time Warner Scientific Atlanta AT8550 remote for the TV to see if the "video source" button would work. IT WORKED!!!! You have to use code 1062. Instructions are:
1. Turn the TV on.
2. Press and hold select and the TV keys until the lights blink twice.
3. Enter 1062. All mode keys blink twice to indicate that the code was accepted.
4. Point the remote at the TV and press power to test the TV.
5. You can then successfully use the "Video Source" button on the bottom left of the remote to change the video mode. VOILA!!!
If you don't have a Scientific Atlanta AT8550 remote, I'm sure you know someone that does. They're everywhere!
Feb 10, 2008 | Sanyo DS31520 31" TV
Turning off Video2 without remote.
HI:Leeray53
THE MEMORY EEPROM WILL BE CHANGED
PROBABILITY IS DAMAGE,
THAT RESET TO DO IT MODE ORIGINAL
FROM LUIS
Nov 17, 2007 | Sanyo DS20930 20" TV
Need codes for a Sanyo TV
I have a 15-2147. The codes from solution 1 didn't work for my remote, so I used the codes listed on Radio Shack's page for the 15-2142. The first code worked. Those codes are: 0154, 1907
Aug 17, 2007 | Radio Shack (15-2147) Remote Control
Sanyo HT28745 28" TV Logo
19 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
