Question about Fujitsu Siemens LifeBook A Series Laptop Universal AC Adapter 18-20v (AC22VPN26P2YR)
Turn off snooze function
How do you turn off the snooze function
  • Fujitsu Master
  • 7,627 Answers
I'm a bit confused by your terminology, "snooze" function? We are talking about a Fujitsu Siemens LifeBook A Series Laptop, Correct? If your referring to the Sleep or Hibernate settings, Open the Control Panel, select Power Options, you didn't post your OS, so here's a Win 7 solution, set to High Performance, select Change Plan settings, under Plugged in, set Display time and set Sleep to Never, select Change Advanced power settings, go through the settings one by one set to your preference. Sleep and Hibernate to Never.
Posted on Apr 27, 2013
How do I switch off the alarm on my CR1003 (model Number) Blaupunct bedside radio?
Setting the Alarm
1. Press and hold the 'Alarm/Sleep/Snooze' button to enter alarm mode.
2. 'Alarm Status' will be displayed and 'ON' or 'OFF' will flash on the second line of the display. Use the right hand rotary control to change the display to 'ON' or 'OFF' as required and press the right hand rotary control to confirm.
Stop the Alarm
When the alarm sounds press the 'Standby' button on the top of the radio. Alternatively, you can press 'Alarm/Sleep/Snooze' on the top of the radio.
Turn off the Alarm
Follow steps 1 and 2 in 'Setting the Alarm' and select 'OFF' in step 2.
Snooze function
When the alarm sounds, you can press the 'Alarm/Sleep/Snooze' button on the top of the radio. 'z' will be displayed in the bottom right of the display and the alarm will sound again in approximately 5 minutes.
Apr 16, 2017 | The Audio Players & Recorders
Getting no sound from speakers on my Cambridge i765 tabletop radio/cd player with ipod dock.
Hi Linda,
Here's a link to the manual to start with.
I see that pressing the snooze button operates the mute function and I presume that pressing Play or the Snooze button turns it off.
Could be that the button is stuck or damaged.
It could be a loose connection or a cold solder joint on one of the circuit boards as well.
I don't know how old your radio is but sometimes capacitors and other components just wear out.
You could take it to a repair shop and they can give you a good idea what the problem is.
http://ecx.images-amazon.com/images/I/C2GnmpZBvBS.pdf
Apr 22, 2015 | Audio Players & Recorders
Nokia 1110 alarm click default snooze to off
when an alarm appears you have two options one is snooze other is off if you select off it wont snooze......... by default snooze will come after 10 mins even if you missed it first time you can off it next time ok.
Oct 21, 2011 | Nokia 1110 Cellular Phone
I am using my mother's Elgin 3400E travel alarm
On my Elgin alarm clock, you just push the nap button and it will add 15 minute increments for a nap. I haven't figured out how to turn it off if I change my mind or wake up earlier than I set it.
Jul 21, 2011 | Elgin Travel Alarm Clock
Is there a way to change how long snooze lasts?
Snoozes are hard-wired into the clock, and are always the same by default. Sometimes a "nap" function will have a different length.
Mar 01, 2011 | Panasonic RC-CD500 Clock Radio
KADIO KD-3806 Model watch. How can we set date and time.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
Nov 12, 2010 | Watches
How do I change time on a KADIO clock 3809
press mode to toggle between alarm time and current time;
Nov 08, 2010 | Watches
How do I enable the alarm on the Eddie Bauer world travel clock with flashlight? I can set the alarm time but I do not know how to enable it. I set it by 2 minutes ahead of the current time and waited for...
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
Dec 24, 2009 | Eddie Bauer Watches
Alerts give a single ring and do not display on screen.
To Do, Alarm and Incoming Messages give a single audio alert but to not display on the screen. The Snooze function does not work although it is selected. Missed calls do not display
May 05, 2009 | Nokia 3120 Cellular Phone
Time Display
A-ha! Those manuals sure do come in handy sometimes. I found the solution. In addition to functioning as a snooze button for delaying the alarm, the snooze button is also a brightness button for the time. If you press snooze one time it changes the time brightness from bright to dim, press it again and it goes from dim to motion sensitive only, press it again and it returns to bright.
I just tried this and resolved my problem. I hope it helps you as well.
Enjoy!
Sep 01, 2008 | Emerson Smartset Clock Radio
Fujitsu Siemens LifeBook A Series Laptop Universal AC Adapter 18-20v (AC22VPN26P2YR) Logo
56 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
