Question about Exercise & Fitness
Hi,I have startrac 7600 treadmill,recently I moved from one place to another in same room.after that I run it for 30mins suddenly its stoped and shows check speed system error and continous trip sound from mcb.I checked the drive sensor pin and it is closed and other 3 pins are open while testing in multimeter.what will be the fault.mcb or drive, pls give me the solution .thanks..
SOURCE: bodyguard t300 treadmill. belt will not turn
Smashed harness created short.
Posted on Jan 27, 2009
maxtreadmill
  • 832 Answers
SOURCE: sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
Posted on Mar 13, 2010
  • 218 Answers
SOURCE: new balance 2500 treadmill shows e1 code and keeps
The motor controller weakens over time because of the excessive amperage draw of the motor do to lack of lubrication (which wears the walk belt and walking deck).
Take an amperage reading of the motor it should be 2-3 amps with no one on it, with someone walking on it it should be around 6-12 amps. I would bet yours is elevated above 6-12 amps.The controller is dropping output because of the friction problem.
The first thing to try after testing the amperage is to lubricate the walking platform. Then retest and see if the amperage comes down and it doesn't shut off.
If it does then the next step would be to replace the walking deck. If the amperage still is up you may need to replace the walk belt second and finally if after replacing the deck and belt, if the unit is still shutting down replace the motor controller.
Posted on Aug 14, 2010
SOURCE: Maxpro 75151877 treadmill switches on OK but then
error1
Posted on Jul 22, 2011
ercupa190
  • 12223 Answers
SOURCE: Hola Ernesto, congratulation for your seccess,, thanks for the great support you had provideded to the community. I own a precor C934 have lower Controller, LPCA problem, and I would like to check if
Thank you brother.
That causes can be
1) optical infrared speed sensor is obstructed.
2) drive motor brusher are bad.
3) speed sensor position is incorrect
4) speed sensor potentiometer adjustment is incorrect
5) speed sensor is faulty.
6) lower PCA is bad
7) lower PCA to upper PCA interconnect cable is bad
8) upper PCA is bad
Remedies: vacuum the drive motor pay attention to speed sensor .
b) motor brusher do not make suffciente contact repair
c) adjust the speed sensor see the scheme attached.
d) locate the speed sensor potentiomente on the lower PCA.set the potentiometer in mid-range
e)measure voltage D.C. for 5vdc, two fo the leads will toggle between 0vdc-5 Vdc.as you rote the speed sensor.
f) substitute a known good lower PCS for determine g) substitute a known good interconnect cable h) substitute a known good upper PCA for determine if is faulty.
God bless you
see the block diagram and my personal TIPS for motor in treadmills
Posted on Oct 12, 2012
Hi,I have startrac 7600 treadmill,recently I moved from one place to another in same room.after that I run it for 30mins suddenly its stoped and shows check speed system error and continous trip sound from...
That is either the controller or the upper board. You'd need a professional out there to diagnose that, or you could call Startrac and they could possibly walk you through diagnosing. Either way, you will need to replace the belt and deck at the same time of this repair.
Aug 27, 2017 | Exercise & Fitness
Star trac 3901 no rpm
A complete description along with a solution can be found at the following link.
NO RPM Error and Why it Displays on StarTrac treadmill
Jan 21, 2013 | Startrac Fitness Products Star Trac 3900...
I have star trac pro treadmill,when i shifted from another place it show the error
1) Run the software calibration for diagnose, troubleshooting.
2) However adjust the reed switch, clean, and tight any wires connector see the diagram
3) adjust the speed sensor, clean, and tigh the wires connector see the diagram attached.
Jul 06, 2012 | Startrac Fitness Products Star Trac Pro S...
STAR TRAC 3500 SERIES ERROR EL4
1) Run the software calibration for easy diagnose and troubleshooting and fix. it
2) tight very well all connectors, and clean
3) Adjust the REED switch, see the diagram , clean and tight the connector very well.
God bless you
Jun 19, 2012 | Startrac Fitness Products StarTrac 3500...
I have just been given a star trac treadmill, how ever i do not have a instrutions manual. Would you be able to help me please.
Thankyou for your reply, how ever, i have worked out how to use the incline on my treadmill myself.
Regards
Tezza
May 04, 2009 | Startrac Fitness Products Star Trac 3900...
Star Trac TR4500 Treadmill. Need help connecting the display
I recently took mine apart if you still need the exact details.
Jan 17, 2009 | Startrac Fitness Products Star Trac 4500...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
