Question about Tools & Hardware - Others
Lm950hc laminator - Tools & Hardware - Others
Can you delaminate a glossy movie poster?
Norine, if indeed 10% did laminate, In all probability it will wreck the poster try to remove it. I am not sure if it will work, could you run the poster through the laminating machine a second time.
May 06, 2016 | Gbc HeatSeal Ultima 65 Roll Laminator
How do I remove the back of my GBC laminator to remove paper that is stuck inside the unit?
First, you must take out 4 screws out of the cover on each side of the laminator , then you will see the screws that hold the back panel onto the laminator. West Laminating secs 405-324-6092
Oct 14, 2014 | Gbc HeatSeal Ultima 65 Laminating System
Is Pergo the same as laminate?
Pergo is the name of a specific manufacturer of laminate flooring
make sure you follow all the instructions in the package when installing a laminate floor. They all have slightly different methods for success.
Jun 29, 2014 | Dream Home - Ispiri 12mm Americas Mission...
Scotch Thermal Laminator not heating up.
well it sounds like you may have cut a wire or pull one somewhere. i would go ahead and take it apart carefully and check everything. may have unplugged something hopfully! let me know whwat happens!
Jan 31, 2014 | 3M TL902VP Scotch 9" Thermal Laminator...
Lamination Problem
You have to go to printer driver, see the general settings and put more darkness(normally it ranges from 0-20, it should be set at 10. Try puting the darkness at 11,12,13, etc until it laminates properly. Don't forget to put back the setting when printing ymcko, or you will burn ribbon.
If the head that prints color is the same that laminates, then you should be cleaning the head after use.
Jan 17, 2014 | Datacard SP75 Plus Card Printer
What is the difference between cold and hot laminators?
Hot laminators are the most common types of laminators. They use heat (220 to 300 degrees F) to apply the lamination. Hot laminators provide a better quality lamination that is more resistant to wear and tear. This is the preferred method of lamination for materials that are not effected by heat.
Cold laminators use pressure sensitive adhesives to bind the lamination film when the material being laminated is sensitive to heat. Certain inks in standard ink jet printers are known to have the ink melt in the machine. There are other types of printers that use heat sensitive paper. For these types of applications the cold laminator is the best choice.
Jan 28, 2013 | Office Equipment & Supplies
What is a laminator?
A laminator is a tool used to plastic coat documents to protect them. Your social security card may have a laminate coating.
Laminate specifications
A typical laminate trimmer is equipped with a 1/4-inch collet. The motor runs in the 20,000-30,000 rpm range – faster than most routers to compensate for the fact that the bits are smaller in diameter.
Aug 27, 2008 | AMANA TOOL 3400 DOUBLE EDGE LAMINATE...
Laminate Trimmers question
Router-neck cavities, pickup cavities; Laminate trimmer- saddle slots, smaller cavities, expanding existing pickup cavities on a finished instrument; Dremel- inlay inlay inlay.
Aug 27, 2008 | Freud FT750T Laminate Trimmer
Tools & Hardware - Others Logo
55 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
