Question about Zebra Stripe S400 Label Printer
Zebra sm400 ribbon warning in
3 Suggested Answers
  • 257 Answers
SOURCE: i have a zebra z6mplus the ribbon keeps breaking
You may have your contrast set too high. If it breaks as it feeds under the printhead (while printing) your contrast may be set too high.
You also could have a ribbon spindle issue. Are both ribbon spindles turning?
Posted on Jul 08, 2009
seltzercool
  • 21 Answers
SOURCE: Zebra Z4 Error message
ribbon in means, you choose direct thermal print method which is printing without a ribbon and yet you print with thermal transfer print method.
just check on lcd panel , change the print method to thermal transfer. and make sure the setting on your driver is thermal transfer too, or else it will keep reverting back to direct thermal
Posted on Feb 19, 2010
Warning ribbon in V53.16.7Z
The "ribon in" warning is because you set the printer to print DIRECT THERMAL insted THERMAL TRANSFER. The first mode is for printing directly on the thermal labels, not for using a ribon. The ribon sensor detects that a ribon is pressent and you get this message. You need to change the printing mode to Thermal Transfer from the printer Setup Menu, or from the Print Driver instaled on PC.
Jan 19, 2015 | Zebra Office Equipment & Supplies
Warning ribbon in
the ribbon sensor it activated, change settings from lcd panel to Direct thernal, and check if settings from driver are correct, Thermal Transfere if using ribbon, Direct thermal if doesn't use ribbon, ru calibration if needed, or if doesnt work, you can do the manual calibration and/or reser to factory default. Hope it helps. Paulo.
May 16, 2014 | Zebra S4M Thermal Label Printer
What does the warning ribbon in mean? Can't get the printer to work
That probably means that your Thermal ribbon is not correctly fixed on the spindle or not in the right inking. Normally on zebra printers the inking must be outside.
Check on your user's manual
May 18, 2011 | Zebra 105SL Thermal Label Printer
Warning Error Ribbon In message is being displayed on screen regularly. What can be a proper reason of it?
if use ribbon, change the seting DIRECT-TERMAL to TERMAL TRANSFER, or run manual calibratio and sensor profile, save, turn off the printer, and on again.
Nov 10, 2010 | Zebra Z4Mplus Label Printer
Warning Ribbon in
If you're trying to print using Direct Thermal and you have a ribbon installed, the sensor will set off that alarm.
If you WANT to print using direct thermal, remove the ribbon.
If you want to print using ribbons change the Print Method in your front panel setup to THERMAL TRANSFER.
Mar 01, 2010 | Zebra S4M Thermal Label Printer
Feb 04, 2010 | Zebra Z6M Plus Thermal Label Printer
Keep getting broken ribbon message on zebra P330i printer
Hello, assuming the supplies are Zebra and there is no discernible damage to the ribbon, it could mean that the ribbon sensor on the printer is broken. if your printer is still under warranty you can ship back to Zebra (Illinois) to get it repaired. The zebra website has info on how to return printers for service. Hope this helps.
Oct 15, 2009 | Zebra Eltron P330i Card Printer
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
My printer display keep showing " Warning, Ribbon in", cannot print multiple label at a time
i have the same problem , but my printer is ZEBRA S4M ZPL
my solution is:
in your barcode software: change printer settings: 1 and 2
1 . in media setting : change media type --> Thermal transfer
2. in documents options , configuration --> use printer settings
by Lin Yu Hsien
Oct 15, 2008 | Zebra Z4Mplus Label Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Zebra Stripe S400 Label Printer Logo
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
