Question about Kitchen Appliances - Others
I have broaster 1600-1800 model it readouts display
I have broaster 1600-1800Electric model.it readouts display "fail"..how can i fix that?
2 Suggested Answers
SOURCE: I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Posted on Dec 18, 2010
I have a broaster that turns on but will barely heat the oil. Does anyone know what would be causing this?
Is it made by the Broaster Company or a spin off like a Henny Penny? Is it gas or electric? If by the Broaster Company would it be a 1800 or a 1600? Give me this information and than I can tell you what the problem is. Not an expensive fix either.
May 09, 2014 | Broaster Pressure Fryer
I have a broaster fryer, and the pc board had burned out (possiblyt due to incorrect installation) need new board or can anyone fix it?
Replace the board. But first make sure the installation is correct. Then double check to see that the installation is correct.
Oct 05, 2013 | Broaster Pressure Fryer
Have a oil leaking problem in broaster chicken fryer
Faisal,
I am a Broaster distributor, and have parts available. Which model do you have, and you are saying the bottom drain valve is leaking, correct?
Jon
jondf1@gmail.com
Mar 14, 2013 | Broaster Pressure Fryer
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
Where can I find a instruction or service manual for a Broaster 1400 E ? jprettie@excel.net Thank yoiu
Hi there.
Try visiting this web for manuals.
http://www.broaster.com/fdsvceqp.htm
Regards.
Jul 05, 2011 | Kitchen Appliances - Others
I have a Broaster 1600-1800 electric model and it takes about 3 hours to heat up. The digital readout blinks on and off saying both lo and intermittently going completely blank. After it heats up the LED's...
If the digital display is going blank, but the Power On light is staying on, the problem has to lie in either the Controller Transformer or the Controller. To determine which, just check the voltage at the 2 red wires that go from the Controller Transformer to the back of the circuit card. That should read around 26VAC whenever the Power On light is on. If the voltage is still present when the Controller goes blank, then the problem lies in the Controller. Contact The Broaster Company through their website, www.broaster.com, and call the Service Department. They can easily provide a Service and Parts Manual to you, as well as help you troubleshoot your problem. Good luck and I hope this helps.
Feb 03, 2011 | Kitchen Appliances - Others
Nov 03, 2009 | Kitchen Appliances - Others
No readout on front panel. UVW-1800
No front panel readout on a UVW-1800 is caused by the audio bargraph display failing. This display has an auxiliary power supply in it that provides power to the front panel display.
Oct 15, 2009 | Sony Televison & Video
Cannot read LCD display
No the display must be replaced. This is a common problem with that model!
Jan 02, 2008 | Canon LaserClass 9000L Plain Paper Fax
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
