Question about IBM Eserver xseries 335, 1 x xeon 3.06 ghz/512 kb, fsb 533 mhz, ram 512 mb
IBM X335 server , but no C2T how to add a vga card
I have IBM X335 server , but no C2T cable to connect to a dispaly monitor,need to disable on board display to add a vga card, how to do it.
  • 3 more comments
  • M H shariff Apr 25, 2013
    I had tried this hyperterminal method earlier itself in VAIN as said.
    I had tried hyper terminal earlier in VAIN
  • M H shariff Apr 27, 2013
    YES I FOUND IT MYSELF
    FOR EVERY BODYS HELP:
    Pin corespondence of C2T cable is
    for Video
    V1 - IC3
    V2 - IC4
    V3 - IC1
    V4 - Nc(Not Connected)
    V5 - I24
    V6 - IC5
    V7 - IC5
    V8 - IC5 (3 of them)
    V9 - I8
    V10 - I24
    V11 - Nc
    V12 - I6
    V13 - IC2
    V14 - I26
    V15 - I7
    Keyboard
    K1 - NC
    K2 - I25
    K3 - NC
    K4 - I17
    K5 - I18
    K6 - I16
    Mouse
    M1 - NC
    M2 - I25
    M3 - NC
    M4 - I10
    M5 - I18
    M6 - I9
    Pin corespondence is
    for Video
    V1 - IC3
    V2 - IC4
    V3 - IC1
    V5 - I24
    V6 - IC5
    V7 - IC5
    V9 - I8
    V10 - I24
    V11 - Nc
    V12 - I6
    V13 - IC2
    V14 - I26
    V15 - I7
    Keyboard
    K1 - NC
    K2 - I25
    K3 - NC
    K4 - I17
    K5 - I18
    K6 - I16
    Mouse
    M1 - NC
    M2 - I25
    M3 - NC
    M4 - I10
    M5 - I18
    M6 - I9
    it is open FOR EVERY BODY'S HELP:
    for Video
    V = VGA
    IC = IBM C2T CABLE
    K = KEYBOARD
    M = MOUSE
    V1 - IC3
    V2 - IC4
    V3 - IC1
    V5 - I24
    V6 - IC5
    V7 - IC5
    V9 - I8
    V10 - I24
    V11 - Nc
    V12 - I6
    V13 - IC2
    V14 - I26
    V15 - I7
    Keyboard
    K1 - NC
    K2 - I25
    K3 - NC
    K4 - I17
    K5 - I18
    K6 - I16
    Mouse
    M1 - NC
    M2 - I25
    M3 - NC
    M4 - I10
    M5 - I18
    M6 - I9
  • 826 Answers
You can use the X335 server without C2T cable. I have searched the article which would make you convenient to understand.
Go for the link:
http://www.dbzoo.com/blog/using_an_x330_without_a_c2t_cable
You can also visit our website. http://www.vtechsquad.com, for any further technical assistance.
Posted on Apr 25, 2013
Testimonial: "Thanks all for the co-operation in trying to help."
How do you play sound on a BenQ PC monitor with VGA no Audio Cables For a HP Proliant microserves Gen 8, I need help
it is a server not a PC, so no sound jacks there.
if you do see 3.5mm line out jack green there'
then it does have sound. easy no? or optical jack.
One can be added, in most or all cases.
If you look at the drawing in the manual here,its missing.
note lack of server sound jacks?
3.5mm or the like.
/9da35884-da52-49e7-ad7b-cf3fc44493be.jpg
Dec 31, 2017 | HP Computers & Internet
What type of video card is compatable
The X335 has an ATI RageXL video controller integrated on system board, but if that is not working then it has two PCI-X slots which would accept any PCI adapter. Check usage here: http://www-947.ibm.com/support/entry/portal/docdisplay?lndocid=MIGR-45476
Apr 25, 2014 | IBM X335 (8676y13) Server
Graphics ibm card onboard
Without being able to see what you are doing it's going to be tough, just buy the cable they aren't that expensive, you have just bought a server.
Apr 25, 2013 | IBM X335 XEON-3.06 512 512/0GB CD (...
I have a new geforce 6200 evga hd card and have installed it in a PCI slot after first having disabled my ASUS integrated ATI 3300 video through the device manager before powering down and installing the...
I am presuming that the mainboard is an Asus model with integrated VGA.
In order to perform the following steps you may have to remove your new VGA board and reconnect your monitor to the mainboard VGA in order to have a display on your monitor.
If your new VGA board is an AGP or PCI express, connecting your monitor to the new VGA board should have been detected and applied the VGA output through the new board. If the new VGA board is a PCI type then go to the new steps to make changes to your CMOS via the BIOS settings.
If not the Asus mainboard may have to have the CMOS setup change through your BIOS settings.
Upon bootup you should be able to hit the delte key and the BIOS screen should come one.
Scroll down to the a view that will show "Onboard Settings" or similar wording.
Select and disable the Asus onboard VGA or video.
If problem still persist, then go to the Assus.Com web site for support on your model Asus mainboard for the maunual, or trouble shooting questions on settings.
Good Luck
Jul 02, 2011 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
IBM X335
hello, you can only use sound card on it. if you want to use the extra graphic card you will need to disable the Video adapter on the motherboard before the Extra graphic card can work.
Aug 10, 2009 | IBM x335 - Xeon P4 2.0GHz (512KB) - 512MB...
Im trying to install agp...how do i disable the on board vga
Hi there.
Remember that if you are swapping from on-board graphics to a card you have to go into the BIOS and tell the machine that the primary graphics adapter is AGP/PCI Express.
Plug the VGA cable into the on-board graphics port, start the computer and enter the BIOS, tell the computer to use the AGP/PCI card as primary, press F10, save the changes and exit the bios.
The computer will try and restart so let it boot to post and turn it off, then put in your card and try to boot again.
Please post back if you need more help or advice.
Good luck and thanks for choosing FixYa!!
Jun 04, 2009 | HP Compaq Motherboard
Can't connect to Monitor
After you have installed one more card , you need to go into the Bios Setup and disable the Onboard card. Then connect the monitor cable to the other card and swith ON.
Oct 13, 2008 | HP Compaq ProLiant DL380 G3 Server
When I hook up my acer monitor it says no imput
Before making sure you have all the plugs & connections in the right place, look at all the pins on the end of the monitor plug that plugs into your on board/video card making sure none are bent or missing. If not, then try swaping with a known working monitor. If good monitor doesn't work either theres a good chance you may need to either add or replace video card.
If none of these options work you can let me know and I'll try to suggest something else.
Jul 27, 2008 | Acer Computers & Internet
Dead
    1. Check your Keyboard-Video-Mouse (KVM) switch. If the system is connected to a monitor, mouse, and keyboard through a Keyboard-Video-Mouse (KVM) switch, or console selector switch, then disconnect the switch and connect monitor, mouse, and keyboard directly to the system. If this solves the issue, please contact your switch manufacturer for support and compatibility on the switch. Some switches can have a firmware update applied to resolve common problems.
      Note: BladeCenter Telco chassis - The KVM module contains keyboard port, mouse port, Power LED, Location LED, Critical Telco Alarm LED, Major Telco Alarm LED, Minor Telco Alarm LED and a video port. The PS2 keyboard and mouse connectors are standard 6-pin Mini Din. The Telco alarms mirror the Telco alarms located on the front panel of the media tray because they use the same signal lines. The KVM module allows the connection of a VGA monitor for system maintenance and control. The video connector is a standard 15-pin VGA. The KVM module is hot-swappable. It is docked into an edge card connector located on the backplane:
    2. If you have your system daisy chained for KVM capabilities using the C2T port (e.g. xSeries 330),
      then you must flash the C2T firmware after flashing the system BIOS, in order for the mouse and keyboard to work. Otherwise, after a BIOS flash, you will lose keyboard/mouse capabilities unless you walk up to each machine and push the select button.
    • If you are using NetBAY Advanced Connectivity Technology (ACT) CAT5 cabling in your rack server, instead of KVM cabling, click here for ACT information.
    1. Check for POST/startup errors. If you are getting a POST/startup error on the keyboard and/or mouse:
    2. Verify that all items are firmly connected to the correct ports, and that the cables are undamaged with no bent pins. The PS/2 style mouse and keyboard ports look identical, but are not interchangeable. The mouse and keyboard must be attached to the correct ports in order to be recognized by the system and to function correctly.
    3. Swap each item for known good units. If a new item works where the original did not, then the original component must be faulty.
    4. If the keyboard works during the POST/BIOS screens, but not in the operating system, check software logs for device driver errors. Contact your software vendor for more support in configuring the I/O devices.
    5. Check the F1 Setup error logs for system component failures or errors. These are found under Event/Error Logs. Troubleshoot suspect components further to determine if the hardware is faulty. If an IBM component is determined to be faulty, please contact your local IBM Support Center for warranty replacement of the part(s). Please have the Field Replacement Unit (FRU) / Customer Replacement Unit (CRU) part number and Machine Type, model and serial number ready.
    1. Run hardware diagnostics. Replace any parts found defective.
    Download the latest diagnostics for your system
    1. If you can down the system, check the keyboard cable connector on the system unit for proper voltage.
    2. Power off the system.
    3. Disconect the keyboard cable form the system unit.
    4. Power on the system and check the keyboard cable connector on the system unit for the voltages shown:
      PIN Voltage (Vdc) 1 +5.0 2 Not used 3 Ground 4 +5.0 5 +5.0 6 Not used
    5. If the voltages are not correct, replace the system board. Otherwise, replace the keyboard.
    6. If these steps have not solved your problem:
    7. musekye318@yahoo.com
    Jun 30, 2008 | IBM NetVista PC Desktop
    IBM Eserver xseries 335, 1 x xeon 3.06 ghz/512 kb, fsb 533 mhz, ram 512 mb Logo
    1,578 people viewed this question
    Top IBM Computers & Internet Experts
    Alun Cox
    Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
