I installed a new system. On power up, all led's on the keypad flashes. When I press the #key zone 1-8 and ready led's keep on flashing. Cannot arm the system?
SOURCE: My Truck honks 1 time randomly when alarm is activated
This is a factory system? don't remember any LED in a factory system.
SOURCE: brother hl-1430 :drum , ready
This just means that your drum life has nearly reached his end.
Note that when you replace the drum you need to perform the drum counter reset procedure, otherwise the leds will keep on burning after replacing the drum unit.
SOURCE: help with wireless window security alarm
"Zone not ready" indicates the windows sensors are not seeing the magnet piece to indicate the window is closed. Are your sensors built into the window jams or are they external wires you can see?
If you have external wires, look for broken wires or broken/missing magnetic bars.
Did the painters paint the window jams? If so, they may have painted over a sensor, though paint usually does not affect the functionality of a magnetic sensor.
Look for the broken wires or broken/missing magnets.
Also - you should be able to bypass the window zones and set the alarm. Instructions for bypassing a zone should be on the alarm head or available online.
SOURCE: security car alarm
on the 3 way pager press function 2 times then press unlock. that will get it out of valet mode
SOURCE: how to activate alarm 2001 bmw 325ix
The flashing light does not mean you have an alarm. They were not standard in the 3-series.
You can get one installed or if you want the dealer can program the lights to flash when locking and unlocking doors even with out alarm. This is called "acknowledgement without DWA"
