Question about Yamaha Televison & Video
Where would i find a remote control rax 100 - Yamaha Televison & Video
Rf20 code for direct tv d12-100
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
DirectTV remote control code list is given.
Oct 04, 2014 | Universal Remote Control Rf20 Master...
RCA XL 100 Commercial Skip TV
Only thing I can think of here is to get a Universal remote, then try these pins to Sync your TV with URM:
RCA - 000,003,004,005,007,009,011,015,048,082,092,094,
096,098,101,102,103,107,113,125,129,067,179,187,188,191,194
May not work 100%, depending on remote functions.
Instead of just buying any, you could maybe borrow one from a friend first of all.
Oct 11, 2017 | Televison & Video
Remote won't change volume, channel numbers don't work
IF its the original remote for the device, the circuit board is just dirty and is not getting good contact. If its a universal then the codes may not be 100% compatible with the device or the remote isn't 100% compatible either.
Jan 23, 2014 | Emerson Used Original NH200UD Remote...
I need the code for teac sr 100 or a replacement for the remote control of teac sr 100 dock (the dock functions ok, but not the remote control)
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check the link and determine which brand remote control should be bought, and buy that brand remote control, according to availability. Codes to check with Teac brand are, 0183,0187,0188. Try this link for more details.
Nov 24, 2013 | Televison & Video
I have a quantum fx rem-100 remote, and i need codes for a daewoo tv
Codes to check with Daewoo brand TVs are 0038.0029,0059,0072,0019. If you wish to get more codes to Dawoo brand TVs with other brands remote controls, check this link. Not mind the brand of the remote control. Only look for codes for Daewoo with its code list.
Feb 17, 2013 | Innovage Jumbo Remote Control
D12 100 code
You can just call direct tv and they will be able to help you
Apr 17, 2012 | Sony RM-AV2500 LCD Touchscreen Remote...
Decode Colors of Clarion RAX 341D harness.
well i think your talking about a car cd player most of them are all the same so
red is power when the key is on
yellow is Constant power
black is ground
blue is your remote wire - for amp or power ant
green and the green - black is your left rear speaker
purple and purple - black is right rear speaker
white and white - black is your left frount speaker
gray and gray - black is your right frount speaker
so on the speaker wires with the black runing down them is alway the neg and the solid color is pos
Mar 10, 2010 | Clarion Car Audio & Video
I have a quantum fx REM-100 remote control and i need the codes for a quasar tv
I bought a Quantum Fx (REM-102) TV remote control for VIZIO TV but the remote control don't response
I did intent some codes to control programming but don
Apr 24, 2009 | GE JASRM24912 Remote Control
Remote stopped working!
To turn off the 100 button you need the original remote.
Order a replacement from one of the sellers below:
Used Original Zenith Z20LCD1 Remote Control
Zenith Z20LCD1 Replacement Remote
Regards
Mar 09, 2009 | Zenith Z20LCD1 20 in. EDTV-Ready LCD...
Televison & Video Logo
18 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
 Grubhead
Grubhead
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
