Question about APC Computers & Internet
Fault finding well connected online smart ups rc1000 with battary but when ups is turn on there is led glow and located battary fault
How do I fix a washed out picture problem on my 46 inch samsung series 7100 led tv?
The common cause of this issue is down to a board that connects the screen to the main circuit video board of the tv. It is usually located top middle of the tv and has 2 white ribbon type wires coming from the top and is normally covered in a metal shield.
There will be a part number on the circuit board, this will be the one to find online which matches your screen. If you got an identical tv with another fault, it may not have the same part as each combination is different depending on the manufacturing line or part revisions.
The part you are looking for is called the T-Con board . Hope this helps.
Apr 02, 2016 | Samsung 7100 Series UN46F7100AF 46" LED...
LG LED tv black screen
led light under screen is not glowing,,check led lights or its related circuit
Dec 28, 2015 | LG 50LN5750 50-inch Widescreen Smart LED...
When power is turned on, splash screen comes on, then no picture. Screen flickers and then goes to black.
Hi Randy,
You have not mentioned the brand and model no. of your tv. Recently I repaired a Samsung smart LED tv for the same fault. One of the Light Emitting Diodes ie. led in the back lights was not functioning. The fault is repairable if you find someone who can open the led panel and repair it.
Good Luck
Apr 08, 2015 | Televison & Video
Y r my glow gauges i just installed in my 99 eclipse flahing in a sequence i have ground stait to car and power to dimmer on my car. Does the same thing when hooked up stait to battary
Not sure exactly what you have but if you hooked up LED's directly to a 12V power source, then more than likely you need to add a diode inline (Load balancer) so the voltage doesn't surge up and down. I would suggest cruising the internet search engines for "how to load balance my LED's" or This might help: https://www.youtube.com/watch?v=LTlsswwm4Ew Or maybe you just bought some low quality LED light's off E-Bay.
Feb 19, 2015 | 1999 Mitsubishi Eclipse
LG magic wand not working
purchase a new remote. there is no way to fix this one
Nov 03, 2012 | LG An-mr200 Magic Motion Remote For Smart...
With out load condition over load led glowing and o/p is not coming
the battery is either dead or the polarity of the ac source is reversed or not grounded causing a fault.
Dec 02, 2010 | APC Smart-UPS 1000VA UPS System
Sir, my laptop CompaqEvo610C can not charging i check my battary on other same model of Compaq it is working and good condition and give backup more then 1hour. when i put the battary in my laptop again...
Since you tried your battery on another pc, then try a different charge power supply on yours. You may have a bad power supply adapter or your battery terminals on your pc may be dirty and need to be cleaned with rubbing alcohol and a cotton swab.
Sep 29, 2010 | HP Compaq Evo n610c Notebook
Unable to connect my vaio to the internet, help
Lets start from the basic troubleshooting steps.
Things to confirm:
1. Confirm that the Ethernet cable inserted properly to the Ethernet port of the Computer.
2. If it is using Wireless network, confirm that Physical Wireless Switch is turned ON and the LED is glowing.
3. Confirm that the Wireless is turned ON in Smart Wi Utility.
If you confirm all the above, go for the further steps:
Uninstalling and reinstalling the driver could resolve this issue.
1. you can find the Ethernet driver here
2. Also find the Wireless LAN driver here
3. There is an update available for the Wireless Adapter Manager here
Sep 19, 2010 | Sony VAIO PCG-K35 Notebook
On my hp 6710b running windows 7, im trying to get wirless to work and it tells me it is not on and that I have to turn on switch on front or side , or use function keys . I have looked everywhere and I...
Here you go. . .(#18 is the button location)
439c6ce.gif 1. Volume mute button with LED indicator
2. Volume scroll zone with up/down LED indicators
3. Integrated microphone
4. RJ-11/modem port
5. Optical drive
6. Media Card Reader
7. 2 USB 2.0 ports
8. HP Fingerprint Sensor
9. Integrated stereo speakers
10. Touchpad with scroll zone
11. Touchpad buttons
12. Hard drive activity / HP 3D DriveGuard LED
13. Battery charging LED
14. Power/standby LED
15. Wireless on/off LED
16. Power button with LED
17. HP Info / HP QuickLook button with LED indicator
18. Wireless on/off button with LED indicator
19. HP Presentation button with LED indicator
20. WLAN antennas (with WLAN option)
21. WWAN antennas (with WWAN option)
Aug 26, 2010 | HP Smart Buy Notebook
Computers & Internet Logo
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
