Question about Echo Chainsaw Cs-370
Cleaning carberator old gas - Echo Chainsaw Cs-370
  • Echo Master
  • 7,482 Answers
Hi John.
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Also be sure to check and clean your spark arrestor in the exaust,if you have one installed on your engine.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws and weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw or weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indention in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me
Bud
Posted on Apr 25, 2013
What causes large gas stream to shoot up through carberator
One of two issues... blocked passageway in the carb or You have installed the float backwards. Release the float pin and orient the float the other way around and re-attach the pin. Conversely, pivot the float on the same pin 360 degrees and re-atch the bowl. Using a welder's tip cleaning tool; about $3 at a auto-parts store, with allow you to insert precision dia. wires with numerous biting groves into the different ports in the carb to clean them out.
Oct 10, 2014 | Garden
Briggs & Stratton 4 cycle Lawnmower engine no fuel from carberator. Fuel is being supplied to carberator but only runs when starting fluid is used. Gas is new. What's clogged?
the float may be gummed up. or the needle is plugged up.
you need to clean the carburetor, old gas left in the carburetor turns
into shellac and gums up in side. you need to take it apart and clean it.
Jun 05, 2012 | Garden
Type of trimmer: Poulan Pro PP125 17-Inch 25cc 2-Cycle Gas-Powered Straight-Shaft String Have not used the trimmer in a couple years due to broken fuel line. replaced the lines today. The primer bulb...
Try cleaning your carb and even buying a rebuild kit. I do not think you have a blockage. Does it even try to start? Cleaning the carb will give you a chance to get rid of any debris or old gummed up fuel and oil that may be in there, give it a try. Good Luck...
Jun 04, 2011 | Poulan 25cc 2-Cycle Gas Powered String...
I have a craftman 17 hp riding mower. It will start and run but Then it will die like it isnt getting gas. Replaced the fuel filter and spark plug.i can let it idle for a few minutes and it seems fine. I...
Remove the bottom bowl of the carberator and replace the needle-valve and float - cleaning this area as you do so.  Sounds like the float has a hole in it or the needle valve in the carb is sticking.  Use some fuel stabilizer prior to storing for winter next time, if not the old gas turns to shellac and makes things stick.
Jun 12, 2010 | Garden
MOWER ONLY RUN WHEN U PUT GAS IN CAB WANT START
Ok, so your not getting gas to carberator, or thru the carberator. Disconnect gas line from carberator, if gas is present thru fuel line, you have a carberator problem. Your rather meger with your mower information so this is all i can tell you. Wish i could be of more help.
May 29, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I can not keep my mower running. It ran great before winter, now it acts like it is going to run.. but dies. I have new gas in it, new oil, and changed the spark plug. What else could it be? craftsman...
Hi, I would suggest taking the main jet out of the carberator and cleaning it with carb cleaner. If you did'nt drain the gas out of it before winter, the gas has gotten old and has plugged up your main jet in the carberator. It could also be that the needle has got **** on it and is stuck, I'd clean that also. Your problem is all in the carberator, and old stale gas sitting in it all winter is the reason.
May 08, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
New carberater and a mechanic needed!
Even if you do it yourself you need to adjust it.I would get another mechanic to look at it also.Have you tried cleaners? 1 type you add to the gas the other you remove the air bonet and spray into the top of carb while running (have someone press on the gas lightly so you don't stall.Have you tried to increase the idle via the adjusting screw? has the auto choke been tested..adjusted? Good Luck.
Sep 17, 2009 | 1984 Honda Prelude
2000 cavalier ran out of gas now it wont work
Remove the coveer to the carberator. Pour some gas into the carberator. If it runs you are not getting any gas to the carberator. It may be the fuel pump.
Aug 20, 2009 | 2002 Chevrolet Cavalier Coupe
My 2 cycle gas trimmer will not start? It's only 2 years old
Have you cleaned the spark plug , replaced it, or the carberation system?
If not, then this could be the problem.
Plug builds up corrosion over a period of time and cleaning is requird. also resetting the gap.
GAs goes stale too to flush out the old gas and put new gas.
Jul 12, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Echo Chainsaw Cs-370 Logo
52 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
