Ca00 error in Toshiba eSTUDIO 4520C PRO
When Power on copier ca00 error is repeating. I tried 2692, 2693 codes in test mode. but no use.
5 Suggested Answers
  • 53 Answers
SOURCE: Turn Off Power Save Toshiba eStudio 150
Don't know if this applies to Toshiba but Xerox machines have the same annoying problem, which is NOT fixable.Xerox machines are used in the EEC who insist that power save is not resettable only able to be set to 120mins max Gotta save the power y'know!
Posted on Jul 19, 2008
  • 132 Answers
SOURCE: toshiba estudio 282 has error code cc90--how to
good day cc90 is the top tray of your finisher (sorter) is causing the fault it is usually caused by there was something heavy put on the top tray or somebody bumped the tray. the bushes on the tray that is lifted by the motor are faulty and need to be replaced by a qualified technician if you need to use the machine please switch off the machine and unplug the finisher (sorter) switch on and the machine will work and obviously not sort or staple i hope that this quick fix will help you out until a technician can repar your finisher (the plug for the finisher is at the back of the machine above the power inlet behind a small cover)
Posted on Apr 06, 2011
SOURCE: Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
Posted on Jul 19, 2012
fivemayur
  • 414 Answers
SOURCE: I have a Toshiba 350 copier ans it has a error code c440
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
When this code not cleat 08-400 then check these all thengs..
1.Check the thermistors
(1) Check if the connectors are disconnected.
(2) Check if the main and edge thermistors are in contact with the surface of the fuser roller properly?
(3) Check if the harnesses of the main and edge thermistors are open circuited.
2. Check the IH board and IH coil
(1) Check if the IH coil is broken.
(2) Check if the connector of the IH coil is disconnected.
(3) Check if the thermostat is blown.
(4) Check if the connectors on the IH board are disconnected (AC input connector and LGC I/F connector
CN455/456).
(5) Check if the IH board or the switching power supply unit are abnormal.
• Replace the IH control board.
3. Check the LGC board
(1) Check if the connectors CN316 are disconnected.
(2) Check if the conductor pattern on the LGC board is short circuited or open circuited.
(3) Replace the LGC board.
please vote me.
Thanks
Best Regards
Posted on Aug 23, 2012
Toshiba 5520c error ca00
the link I attached might help.
Good luck & have a nice day!
Thread Toshiba studio 3530c CA00 error code
Jul 14, 2017 | Toshiba Office Equipment & Supplies
How can I fix a CA00 error code?
Well, you don't specify what printer you have, but a Google search for that error code mainly comes up with Toshiba, so try this link, which has several suggestions:
There are also past discussions of that error in Fixya:
Questions Answers for toshiba ca00 error
May 10, 2016 | Office Equipment & Supplies
How do I repair a ca00 error
CA00 is a image problem.
It can be caused by insufficient of developer materials or main charger problem.
Mar 04, 2015 | Toshiba E-Studio 2830c Color Copier...
Toshiba E 6520C have problem CA00 I have probem
I agree this would be best to have a service technicians service this machine being if an attempt is made from first solution and doesn't solve the issue and a service technician does have to be called it may cost more.
Oct 20, 2013 | Office Equipment & Supplies
Error code CA00 what is that
Communication error try rest in 08 - 690
Sep 10, 2013 | Toshiba Office Equipment & Supplies
Mar 19, 2012 | Office Equipment & Supplies
Toshiba eStudio 2500c - CA00
This is a pretty complicated issue/problem. there are 5 pages devoted to this issue in the service manual. This issue would be best handled by a technician. but you could try the following....
[CA00] Color registration abnormality
<Color toner low density>
Turn on the copier holding down 0 and 8 and wait till it boots up into its service mode..then enter code 2692 “Prevention of color toner low density / change the zero to 1.
Then change code 2693 “Prevention of color toner low density / Judged number of sheets setting” value to 40 (default 20).
Make sure you have cleaned the main charge units by fully extending the rods with the green handles for each color.(open the front door) and use the plastic wand attached to the front door to clean the laser glass for each color..there is a small **** under each color unit to slid the wand into..felt side down on the wand.
Like I said there are several other complicated ways of fixing this.
Jan 15, 2010 | Toshiba Office Equipment & Supplies
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
Error code H3 displayed on Xerox XC1044 Copier
this is the solution:
To enter diagnostics: Turn on the power and within 4 seconds press the following sequence: 'Clear', 'Exposure Mode', 'Clear', 'Exposure Mode' (Exposure Mode is the button on the far left). The console will go completely blank.
To enter a code: Select the first part of the code using the copy quantity buttons, followed by the 'Print' button, then the second part of the code followed by the 'Print' button again.
To exit diagnostics: Press 'Clear' repeatedly or turn the power off.
*To clear a fuser code:(14) Enter diagnostics, select '14' followed by 'Print'... exit diagnostics.
H3 stands for high temperature at the fuser.
Mar 15, 2008 | Computers & Internet
278 people viewed this question
jasbo
jasbo
