How do I set the alignment
Picture is not strait
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
You have to do convergence alignments. The proceedings are too much to type in here by this window. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name and model number to your device into its search box at the top right of display window.
Posted on Apr 25, 2013
Frigidaire dryer fde564les0 belt wont stay on. New belt and tensioner assembly
cant trace model number please verify and post.. until then make sure drum turns freely and that idler arm is aligned strait with groves on motor that belts is on groves down
Jan 07, 2015 | Dryers
2006 ridgeline steering wheel not strait after aligment
Return the truck to the place that did the alignment.
They did it wrong.
Jun 22, 2012 | Honda Ridgeline Cars & Trucks
I have a 2004 Dodge Intrepid 2.7L SE. As I was pulling out to make a 3 point turn (turning left) my car was hit. When it hit, it pushed my tires strait but the steering wheel stayed left. So now when I...
Fixed Properly: You need to bring it to a shop- Modica Bros/Pep Boys/Firestone/Disount Tire/Etc. It's a simple alignment and it'll cost somewhere in the $120 price range - possibly less.
Sep 30, 2010 | 2004 Dodge Intrepid
Lines on top and bottom are not strait. thay are bowl
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 16, 2010 | Philips 60PP9202 60" Rear Projection...
Looking for the correct timeing marks for crank and both cams on a 1993 subaru impreza and at what pisition should the number 1 cylender be at?
easy money, the crank pully cog has a little hash mark on one of the nipples and that lines strait up and down with the hask mark on the tup of the oil pump directly below the crank sensor, the two cam ullys each have a hash mark on the outer edges and the both align strait up and down with the marks on the rear timing covers.
Mar 08, 2010 | 1993 Subaru Impreza
2001 Honda 929rr. The front end is out of alignment
set the bike so the front end is off the ground a little then loosen all bolts on the triple clamp that hold the fork tubes then with the front tire held between your knees turn the bars until aligned then retighten clamps.
Mar 01, 2010 | 2001 Honda CBR 929 RR Fireblade
Hard to keep strait in the road have to keep turing stering wheel
Your in need of a front end alignment. While that being done, they will inspect the front suspension
Oct 06, 2009 | 1997 Dodge Ram 1500 Club Cab
Doors not aligned
unbolt then make sher that bolt holes are ok
then check the hing make sher that there not bent up or any thing if they are then get new or tri to bend strait
Jul 29, 2008 | 1986 GMC K2500
Slanted Picture
It sounds like the dm bd. is loose. This is the module with the DLP IC on it. With the back off of the unit their is a module directly in the middle of the chasis that has a metal shield around it. Try to move it gently to see if it is loose. If it is loose that is what the picture is tilted. This is very difficult to align, but if you have someone watch the picture as you gently move this module you can get it strait. Then locate the screws that keep it tight and snug them
Mar 21, 2008 | RCA HD50LPW175 50" HDTV
Picture cut off
No adjustment needed on these LCD projection. Your problem is in your setup menu. Your default is now is set ZOOM. That is why the bottom of the picture is cutting off. Go to Menu, setup and screen size or something close to that.
Best regards
Circuitcity
Jul 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
