Question about Garden
Craftsman lt4000 runs for a couple of swipes on lawn then quits and wont start
SOURCE: craftsman lawn tractor wont start
your fuel filter could be plugged
Posted on Jan 19, 2009
  • 6 Answers
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Posted on May 31, 2009
smartr10U
  • 1305 Answers
SOURCE: Craftsman 24Hp Lawn tractor engine dying out
1. check the oil level... don't want the auto shut off to be the problem due to low oil level
2. pull the carb bowl and check for residue. Spray out the needle valve in the carb, spray out the bowl and any jet openings you can find...spray them out too.
3.When you winterized, did you put fuel stabilizer in the tank? If not, drain the tank and refill with fresh...
4. check the air filter element and make sure it is clean...
let me know how it goes...
k
  • 376 Answers
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
Posted on Jun 08, 2009
  • 74 Answers
SOURCE: lawn mower runs well from cold but if stopped won't start
Sounds like it's running rich. If the mixture is slightly rich it will start well when cold, but when hot it floods. Check the air cleaner to be sure it's not clogged/blocked. Get a new plug for it and if this happens again just install the new plug - the new plug won't be fouled with fuel. If it started with the new plug then you're on your way to a carb adjustment (that is if the air filter/cleaner is clean)
Posted on Aug 29, 2009
Won t stay running
could be a bad coil
Oct 15, 2013 | Craftsman Garden
The oil drain plug (at bottom of elbow) is stuck on Craftsman LT4000 12.5 hp riding mower - I can't move it either way. Before I force it, I would like to make sure which way it should go to remove...
Hi, because you are looking down on it, it needs to turn clockwise. But if you were looking at it from underneath it would turn counter-clockwise. I hope that makes sense. Regards Phil
Aug 28, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I need a manual for oem 190-620a snow blade
did you get your manual or not i have one that i can copy and fax you if you still need one
Sep 06, 2010 | Mtd 46" Dozer Blade, Fits All & Yard -...
8 year old Eagle I Craftsman 6.5 starts and quits? Help!
it sounds like a gumed up carb strip the carb and clean out all the running jets with carb cleaner,,,dont go poking wire into the jets you will only distroy them,,,also check that the air cleaner is clear if its cloged up the engine cant breeth and wont rev up and it will be running very ritch as well,,,check you have good flow of fule from the fule tank,,,winter takes its toll on garden tools that are stood up most of the time
Jul 10, 2010 | Craftsman 22" Rear Bag Rear Propelled High...
Instructions for replacing deck belt for craftsman2 12.5 hp riding lawn mower
when engaging my blades on my craftsman lt4000 12.5 hp lawn mower the pullys wont engage them
Apr 17, 2010 | Craftsman Garden
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
