Question about Garden
Not enough fuel to run stihl ms361 chainsaw - Garden
  • 2692 Answers
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
slohry
  • 87 Answers
SOURCE: Engine wont run.Stihl 028 chainsaw.
Remove and clean the exhaust port, muffler and spark arrestor screen. Also clean the air filter.
Posted on Apr 09, 2009
Dolfoff
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
SOURCE: Fuel line for Stihl 025 chainsaw
there is a good video on this problem on you tube. should be easy to find.
Posted on Dec 31, 2009
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
Where can I get a STIHL-CHAINSAW MS361-REPAIR-SERVICE-MANUAL
Here's another service manual for your Stihl,they don't make this model no more. Stihl MS361 Service Manual Cylinder Engine Clutch
May 31, 2017 | Garden
Hi Terry,here's a owner's manual, if that will help,I have a Stihl chainsaw,What is wrong with your's? https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/MS361C_Manual.pdf
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
Stihl 028 chainsaw runs good for awile then bogs and dies
Check fuel filter, fuel tank vent and possibly clean carb and replace carb diaphrams
Feb 12, 2014 | Stihl 028 Chainsaw Crank & Case
My stihl sh 55 blower starts then shuts off
If it is getting smokey exhaust befor stopping it is getting too much fuel. If not smokey it is not getting enough fuel. If smokey first take out the air filter and clean it. If it runs fine your done. If not smokey open the high needle valve (marked with an H) on the the carb a little (no more than a 1/4 turn).
Aug 02, 2013 | RTO Spur Sprocket For Stihl 017, 021...
Missing 025 Stihl chainsaw part
Hi, you are correct it is the tank vent. Go to a stihl shop and purchase a new one, regards Phil.
Jun 03, 2012 | Stihl Garden
I have a 026stihl that won't start
It would be a good idea to check the compression first to make sure there is enough to make the saw run. A person can run in circles trying to figure out an issue if the compression is below 100 psi, there should be about 150 psi. Older Stihl saws are also notorious for cracked fuel lines. Check the fuel line to be sure it is ok, also check the spark.
Aug 04, 2011 | Stihl Garden
My Stihl chainsaw starts up but then it won't stay running. Changed spark plugs and tried new gas, but didn't fix the problem.
Jets in chainsaw may have build-up. A good build-up remover is called SeaFoam. Add this by direction to the gas. When using the SeaFoam you need to run full throttle with intermittently full choke until motor runs smooth with no choke.
Double check 2-cycle mixture. Too lean mixture in the chainsaw wont stay running.
Sep 05, 2009 | Garden
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
