Question about AKG K 495 NC Noise canceling headphones
Headset Manual charging indicator
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
Caution
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I have a h700 bluethooth and dont have a manual. what color should the light be when connecting to the phone, in use, and charging.
The indicator turns red when charging and turns green when fully charged. The headset will flash in purple when it is in discovery mode (mode where it is looking for a device to be paired with it). If it has already been paired with a device it is blue and then flashes blue when it is paired. The link for the manual is below. http://www.motorola.com/mdirect/manuals/QG-H700_9499A88O.pdf
Jul 23, 2011 | Motorola Mobility H700 Wireless Headset
Does the LG HBM-210 have to be on to charge
According to the instructions provided by the operator manual...
"Connect the charger to the charging port.
- When the charger is connected, with the power on or off,
the Headset will turn off automatically, and cannot be used.
While charging, the LED indicator will show a solid blue light.
- The buttons will not function while the device is charging.
- It takes 2 hours to fully charge the Headset.
- When charging is complete, the LED indicator will turn off.
Jan 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
MadCatz8860 Won't Charge
when you buy it for the 1st time, charge it up for double the reckemended 1st charge
Apr 19, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Omnitech 2.0 Bluetooth headset. No charge indication?
I have the same headset. Make sure that when you place it in the little charging cradle that the ends are snugly fitting together. It is a very flaky design in my opinion.
If all else fails, call OmniTech (800.351.0245) and see what they can do about it.
Apr 07, 2009 | Cell Phones
All of a sudden my CS 55 with plantronics stopped working. It shows that its on but the headpiece isnt charing and also doesnt work. Any ideas why?
If the Plantronics CS55 wireless headset shows that it is on, you have to make sure of the following things.
a. the green LED on the base turns on when you turn the call switch on from the headset.
b. the small green LED on the side of the headset is blinking.
c. the telephone headset is lifted from the cradle.
d. if the headset is not charging and the Amber light on the base does not blink when you place wireless headset on it; trying placing the headset more firmly.
e. If the headset is not charging and the Amber light on the base does not blink even after placing the wireless headset firmly on the charging cradle, you may need to change the battery.
Alternately you can try resetting the Plantronics CS55 wireless headset.
Reset Plantronics CS50, CS60 or CS55 Wireless Headset
If you have problems with the sound or connection of your Plantronics CS50, CS60 or CS55 wireless phone headset, you may want to try to hard reset it using the following steps:
Note: Ensure the IntelliStand switch (on the right side of the charging base) is in the - position and NOT the = position.
1. Press both the call control button and the listening volume/mute button for 5 seconds. When the indicator light blinks release both buttons.
2. Press the call control button again. The talk indicator light will again blink to indicate the headset is back to normal.
3. Disconnect the AC charger from the AC charging jack for 5 seconds.
4. Reconnect the AC charger.
Now give the Plantronics headset a try.
Jan 10, 2009 | Plantronics CS55/HL10 Wireless Office...
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
for 3 seconds to power off.
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Jul 13, 2008 | Plantronics Explorer 320 Wireless Headset
Charging H550
The indicator light turns red when the battery is
charging. It may take up to 1 minute for the
indicator light to turn on. When the headset's
battery is fully charged (about 2 hours), the
indicator light turns off.
Jan 09, 2008 | Motorola Mobility H550 - Bluetooth Headset...
AKG K 495 NC Noise canceling headphones Logo
24 people viewed this question
Top AKG Audio Players & Recorders Experts
Vito Vacirca Jr.
Ben Armstrong
Edward Carrington...
Level 1 Expert
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
