Help to reset pin code of heater module (Model N-g1/Lo )
My Brivis ducted heating system doesn't work. I sought and paid for technical support from Brivis to fix the problem. The unit however is still not working. I called Brivis again to notify that the system still doesn't work. The Brivis technical service then recommended that I replace the entire system with a new one. This system however is new and in good condition and I am not yet ready to pay for an entirely new system. I decided to check the system myself. As advised by the Brivis technical service, I opened the top cover of the heating system to check its display. The display showed the message "Secured". I held and pressed the module's round button. The display then showed the message "Enter PIN". I entered the numbers "1111" as advised by the owner's manual, but the display remained to show the message "Secured". Does anyone know how to bypass this problem? I need to reset the pin code of the heater module to continue but the module keeps displaying "Secured" whenever I try to enter the PIN code. Any help would be appreciated.
  • Asia Vlogs
    Asia Vlogs Jun 23, 2017
    I'm experiencing the same issue please advise....how do I reset the pin?......my wife accidentally changed the pin
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 83 Answers
They are correct, the board is bad.
Posted on Apr 29, 2016
  • 1 more comment
  • Sherlock Ohms
    Sherlock Ohms Apr 29, 2016
  • Asia Vlogs
    Is that an expensive part to replace?
  • Asia Vlogs
    Asia Vlogs Jun 25, 2017
    More information please....is the board replaceable?
SOURCE: Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Posted on Nov 08, 2009
  • 3 Answers
SOURCE: Error message 35 Hi brivis ducted heating
I had the exact same problem and called 1300brivis. They told me that the error means the thermister needs to be replaced. My unit is also out of warranty but they are still going to come out and fix it.
Posted on May 05, 2010
  • 3247 Answers
SOURCE: My brivis climate system (auto EMS series EMS20)
Have you seen this Instructions Manual which explains some of the actions to check the system.
Have you checked that the gas supply to your premises is working well. You will have to confirm there is no air in the system which is preventing the pilot from re-igniting.
Depending on where you live in Melbourne you can find a local repair technician who can help. Try the local newspaper classifieds. For the north & west try this mob. You can also try Service Central and post the job.
Hope the unit works soon. It must be awful not to have heating in winter.
Posted on Aug 22, 2010
bugoy31
  • 1238 Answers
SOURCE: Brivis HE30 Gas Ducted Heating. My
Welcome to FixYa!
Error Code 63,56,70 and 71 intermittent is caused by either of the following: 1. A very low setting on the controller less than 16 degs. 2. Or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
The power supply needs to be reset due to the fault being detected.
Solution:
  • Put the power supply to heater off first
  • Reset the heater panel
  • Press the button again to show EMS on
  • Then set the heater to the required temp. after turning on to the heating mode.
Thank you for using FixYa.
Have a great day.
Posted on Jul 17, 2011
  • 16 Answers
SOURCE: brivis buffalo 20 problems
Potentially bad pilot valve. clean pilot. then report back.
Posted on Jun 12, 2012
Brivis ducted Heater won't get above 19 degrees ,
could be broken ducting letting hot air escape or on the intake side drawing too much outside air in. could be the fan unit not pushing enough air
Jul 26, 2013 | Cars & Trucks
Hi i have a brivis eh 30 unit that comes up with error 65 and 30 the display inside the unit says fan limp, if i reset it from the unit it works for about 1 hr then the same thing can anyone help please
Hi. Here are the error codes for your Brivis Heater. Error Codes 30 - relating to speed sensor, 40 - overheating, 65 - motor lock-out. Usually resetting the unit will resolved the issue. In your case, you already reset the unit and problem came back. This will require immediate attention by Brivis technician.
Jul 12, 2010 | Heating & Cooling
Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
May 31, 2010 | Heating & Cooling
Error code 62 on Brivis Me20 ducted heater
Hi
Error 62 is related to hot surface ignitor (HSI)or/nglo module
you can check the resistance of the ignitor should be less than 10 oms @ 20 degrees
failing that, if you incomming suppy exceeds 270 volt will also result in error 62
May 04, 2010 | Heating & Cooling
Brivas ducted heating not firing up. Gas supply ok electic supply ok. Spanner symbol on screen and Error 62 Model ME 20 E
Hello, We have Brivis Me20 gas ducted heating. It suddenly stopped working and gives error #60. Sometimes after pressing reset several times it fires up for a short period then fails again. Any ideas what might be wrong?
Thanks,
J
Apr 30, 2010 | Heating & Cooling
Apr 12, 2010 | Heating & Cooling
Sep 22, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Brivis Ducted Heating system. No display on Programmable controller inside hoiuse. Electronic Control (Model 14100) located on Heater (outside house)displays "Searching". Have turned off...
I have an identical issue with my Brivis.
Did you get a solution?
Mine can be running, then goes blank and says searching. it will eventually come back.
Just wondering if you had to replace the 14100?
Cheers
James
Jun 10, 2008 | Heating & Cooling
Brivis Heater help
These Brivis guys and girls are a rip-off. They are only out to take your money. Then can easily ask you to do just as mentioned above. And pronto all works in 3 minutes to be precise.
It is just the power supply reset required due to a fult being detected, either caused by a very low setting on the controller less than 16 degs. or a higher than 25 degs. setting causing overheating when the damper outlets are mostly closed.
So, put the power supply to heater off first, reset the heater panel, press the button again to shaow EMS on and then set the heater to the required temp. after turning on to the heating mode. That simple! That is if it is the error 71 HI.
Jun 01, 2008 | Heating & Cooling
Heating & Cooling Logo
953 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
