Question about Air King SEV28S Kitchen Hood
Hood vent fan and light for NuTone Model RL6200-H-B
I have twisted all the black wires and white wires together but still nothing works. Help
3 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: I have an old air
White from the hood goes to white from the house supply.
Red and Black from the hood go to black from the house supply.
Posted on Feb 20, 2011
barterjoe
  • 344 Answers
SOURCE: BLACK, RED, AND WHITE WIRE COMES FROM HOOD BLACK
This picture might help. Do you have a light too?
if not just take it out of the loop.
best wishes
Posted on Feb 21, 2011
Black wire, white wire, and tan wire coming from ceiling. New fan has blue, black, white wire and green wire on the bracket how does it hook up
1. Have on hand either wire connectors or electrical tape
2. Look at the wires coming from your ceiling fan. The black wire from the ceiling fan is the hot wire that runs the motor and turns the fan blades. The white wire is neutral and completes the fan circuit. The blue wire is the hot wire for the ceiling fan light fixture. The ceiling fan motor does not have a ground wire.
3. Find the short green wire or the green ground screw on your ceiling fan hanging bracket. Attach the bare copper wire from your electrical box to the short green wire by twisting and orange wire connector to the two wires. If you only have a green ground screw, wrap the bare copper wire around this screw and tighten the screw against the bracket to secure the wire.
4. Match the end of the white insulated wire from the ceiling fan to the end of the white wire from your electrical box. Twist a wire connector onto the two wires to complete the neutral circuit.
5. Connect the black insulated wire from the ceiling fan to the black insulated wire from the electrical box. If you do not have a separate toggle switch on the wall to operate the ceiling fan and light separately, grab the blue wire and place it with the black wire from the fan motor and the black insulated wire from the electrical box. Twist a wire connector to all three wires. If you have the additional toggle switch, connect the two black wires together with an orange wire connector, and then match the blue wire and the red wire together. Twist another orange wire connector on the red and blue wires
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jamie_580d75bd3bb6d659
Nov 11, 2017 | Dryers
Nutone bath fan how do you clean the vent
Usually the vent cover pulls straight down, and is held in place with 2 V-shaped metal spring wires.
Squeeze each spring wire together to release cover from ceiling box.
Use vacuum to clean vent fan housing. Some vent fans can be disassembled and motor housing removed for cleaning. Do NOT use water on electric motor. Simple vacuum, or dry toothbrush cleaning is good enough.
Spay tiny bit of WD40 on the fan motor shaft or add tiny dab of white grease if desired.
The plastic cover can be scrubbed with soap and water, rinse to remove soap residue, and when dry, paint with aerosol spray paint using 3-5 very light coats applied in 5 minute intervals.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 28, 2012 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Just installed fan. Light is functional but fan is not working. Any suggestions?
You either didn't plug the fan in or when you wired it up you missed a wire. There should have been 2 black wires and 2 white wires in the juct box from the fan/light along with the feeder wires you broght from the switch. All whites go together and all blacks go together. Green and bare copper are the grounds and need to be fixed to the unit itself.
Jan 29, 2011 | Broan-NuTone Home
Need wiring explained to me for nutone 763rln ceiling fan-light
I'n not quite sure how the other answers above answer this question about wiring, but here's the scoop. I will assume you have ONE switch to turn on the fan/light, and it is an already existing switch, and the old fan/light has wiring run to it. FIRST, be sure the wiring run to the fan is NOT hot; test it with a tester ($10-$15 @ hardware stores) - you should own one - they come in handy. You never know how someone else wired the switch; they might have interrupted the neutral (white) wire and not the hot (black) wire. If the black wire in the old fan is still hot, shut off the breaker before working on it. You will see a small screw on the bottom inside of the fan box; remove it,take out the fan assembly, and it will expose the wiring to the two (one black; one white) plugs. Strip back about an inch of all 4 wires and twist the two white ones together; do the same for the black and the blue. Now you have 3 wires to connect to the house wiring running to the fan. On the outside of the fan box, very near the wiring, you will see two 1/2" knock-outs; they are about the size of a nickle, with a slot in the middle. Stick a flat blade screwdriver in one of the slots, and twist it back and forth until it breaks out. If you don't have one, buy a wire holder (DANG! for the life of me, I don't know what they are called!) that fits into the knockout hole, and holds the nomex wire securely. Give yourself enough wire sticking through to be able to work with. Strip about 3/4" off the black and white wire. Twist the black and blue wires you tied together earlier around the black wire clockwise, all the way up to the tip, and secure with the proper size wire nut (use one with METAL insert, no plastic, thank you!). Do the same with the white wires to the white nomex home wire. Ditto the green wire to the bare ground. I've found these come with barely understandable directions. What the directions don't tell you is that you need to have the edge of the metal box nearly flush with the ceiling. The outside edges of the light fit inside the plastic housing; THEN, plug in the white plug from the light into the outlet, Now, unscrew the acorn nut from the long screw sticking down. Put the light fixture up, and affix the acorn nut, and tighten it. I assume no liability for any of the above directions; if you are not sure about anything, hire a qualified person to do the install for you. Electricity can kill. Proceed with caution; following all the above directions does not guarantee that you will not be hurt or injured.
Dec 11, 2010 | Broan-NuTone N-763RLN Combination Light...
Installing Broan exhaust fan/light/night light model QTR070L. Am connecting with a single switch power source. Fixture has three whites, one blue, one black, one red and the ground (green). In what color...
Hi .. with only bone switch for this combo unit, the connections would be like this .. all ahites together with the romex white , all colors, red, black, blue with the romex black, all greens together IF you had more than one switch , then the red, black, blue would be connected separately to one switch eack and separately to a 4 wire romex from the switch to the combo unit.
Apr 17, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
Tried to install a ceiling fan to replace a chandelier. light on fan and fan itself works but only by the pull chains, it will not turn off or on by the wall switch that controlled the light. when i...
I can help with this but I need some more clarification. Does the switch on the wall not do anything at all, or does it turn them both off or on. The black wires are the power wires and the whites are your neutrals. You figure out what wires are coming from your switch. If there was a switch on the wall that controlled your chandelier before that there has to be a white and black wire that go to that switch. Look at the switch in the wall. If all you see in the switch box is a black and white wire then they did a switch loop, which means they started the power up in the fan box, sent it out to the switch through the white wire and brought it back to the fan through the black wire in which case the one white wire up in the fan box is a powered wire. If there are four wires in the switch box (2 black two white), then they brought the power into the switch box, tied the whites together as neutrals and connected the blacks to the switch. So then up at your fan the white is neutral and black is power. To wire a switch loop at your fan, find the power wire, connect it to the white wire that goes out to your switch and the black wire from your switch will get connected to your fan motor and fan light. If it was not a a switch loop connect fan to the black coming from the switch and all whites will get tied together. Good luck!!
Apr 16, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Replacing old fan with a new broan fan and light kit fan works but light does not come on.the fan has a white and black wire and the light has a blue and a white .i pu the white and the blue to the main...
White wires are neutrals and must be tied together to the power lead-in white wire. The black goes to the hot interrupted by the switch. The Blue wire is the hot for the fan but is interrupted by a separate switch. If you want to use one switch then the blue goes to the same black for the motor.
Jan 31, 2010 | Broan-NuTone 679FL Combination Light Fan...
Wiring Bathroom light/vent/heater switch with 3 separate controls
Wiring a bathroom combination vent, heater, light 3 way switch means more wires. In brief, you need to run two cables - one a two wire and one a three wire from the switch to the fan.
Incoming power will have white black and ground.
The two wire cable for the switch to the fan will have wht, blk, and ground.
The three wire will have red, blk, wht, and grnd.
The switch will likely have 2 blacks and a red coming from it, with two blacks and a red on one side, and a single black on the other.
The fan should have a red, blue, green, black, and white.
On the fan end: Group all green/copper grounds together and use a wire nut to fasten them together. Tape the nut to the wires.
There will be five white wires coming through. For ease of handling, using wire nuts, connect two on one nut and three on the other.
connect the blue to a blck. Connect one red to one black, and the other red to the other black.
The switch will have one red going into the 3 wire cable, a black going to the 3 wire cable, and a black form incoming power to the side opposite the 3 wires, and a blck going to the two wire cable.
There. Confused?
May 26, 2009 | Broan-NuTone FAN CONTROL SWITCH
Sidewinder Fan Works but not the Light
As you were assembling the wire from the fan motor to the house wiring, there should have been two wires labled. One would have been labeled "FAN" and the other "LIGHT". To properly attach the wires, (be sure the power is off) twist the thin labeled black (FAN) and blue (LIGHT) wires together. Now attach those two twisted wires to the black house wiring with one of the supplied wiring cap. Finally attach the thin white wire to the white house wire with supplied wiring cap. Your fan is now ready for operation. If you had performed all these steps when you first assembled the fan, then the thin black wire going to the fan has come loose. Should your ceiling fan still not run after all that, then it's time to return it where you bought it because either the pull chain switch is defective or the manufacturer produced a defective piece of merchandise. If you found any of my suggestions to be helpfull, please rate my solution. Thanks D. Lange
Apr 19, 2009 | Hampton Bay Sidewinder 04890 Ceiling Fan
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Air King SEV28S Kitchen Hood Logo
135 people viewed this question
Top Air King Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you an Air King Kitchen Range Expert? Answer questions, earn points and help others
