Question about Saws
Wiring program for irobi ATS 1825 table saw - Saws
3 Suggested Answers
  • 8404 Answers
SOURCE: i need the wiring diagram for my 10 table saw
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Posted on Nov 03, 2009
agent91
  • 2100 Answers
SOURCE: I THINK IVE BURNT THE BRUSHES OUT ON MY RYOBI ETS
You can change the brushes easy enough but I don't think that is the problem. The brushes are a standard size, can be bought at any hardware store. Just pull the caps off and remove the brush, slide in the new one, all set. But,,, I have a feeling the motor went kapooie, The brushes usually don't smoke, but a burned out field or armature will. Check the motor to make sure it spins free with the belt off, or the blade off if it is direct drive, then do the brush change, if that doesn't do it, you will have to take out the armature and have it checked for ground, and then check for loose wires, burned rotor, and if that checks out then the field is shot. One of the 3. But it could be a bearing. Hope this helps.
Posted on Jul 26, 2010
How do I get the burned out motor out of my ets 1825 table saw
torx screwdriver or bits to unscrew it.
Sep 23, 2016 | Saws
Model 36-979. Where can I get a wiring diagram for the power switch?
images for Delta Table Saws wiring diagram for power ...
Replacing a Table Saw Power Box and Switch. Rocket ...
? 7:45
https://www.youtube.com/watch?v=8A25b9BjkmY
Feb 12, 2014 - Uploaded by AdventuresInDIY
See how an in the way power box on a 10 inch Delta table sawwas switched out ... Would you happen to have a wiring diagramfor your saw.
Oct 28, 2015 | Delta Saws
Switch wiring
Did you manage to get in contact with the manufacturer of your saw? They would surely help you with your problem.
May 03, 2013 | Makita MLT100 TABLE SAW FOR 220 VOLTS
Ryobi ets 1825 table saw cuts out
Sounds as it is overheating. When have you last changed your blade. Also cut slower may help if your blades are dull or if the thickness of what you are cutting is too thick. Don't use an extension cord neither. Hope this helps.
Nov 10, 2012 | Audio Players & Recorders
Table saw moter burnt out.
Sears carries a good selection of capacitor-start replacement motors that should fit your saw. Most of these motors can easily be converted to 230 volt operation which is a recommended procedure (almost instant starting!). Don't try to have the original motor rewound as it would cost several times the replacement cost. That service is only used for very expensive high-horsepower 3-phase motors as a rule. Hope this helps!
Feb 08, 2010 | Saws
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Nov 02, 2009 | Craftsman 10" Table Saw
Where to buy a new motor for ryobi ets 1825 table saw
I have been in contact with Ryobi and they tell that this is a bad model number could you please recheck or call Ryobi direct at 1-800-525-2579
Jul 16, 2009 | Ryobi Saws
Wiring diagram for model 137.248830
SAME SAW I HAVE, I ASSUME YOU DONT HAVE THE ORIGINAL OWNERS MANUAL. GO TO SEARS.COM, AND TOWARDS THE TOP THERE IS A "PARTS" HEADER. CLICK ON IT AND ENTER MODEL NUMBER WHEN REQUESTED, THEY WILL ASK UP IF YOU ARE LOOKING FOR A SPECIFIC PART OR MANUAL . HOPE THIS HELPS
Mar 24, 2009 | Craftsman 10" Table Saw
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
