Question about Saws
Rockwell/beaver bandsaw blade size
Model num 28115the blade size for 10in bandsaw
Sorry don't know what happened; I want to know the max. size saw blade for this mo.
Without model number hard to tell, but might be 10in, the most common.
May 26, 2015 | Saws
I need to find the size and length of a powermatic bandsaw blade. Model PWBS-14
93.5 inches
Do you not have internet? I found the specs for your model instantly on Powermatic's web site. Don't be so lazy!!
Feb 27, 2015 | Powermatic 14" Bandsaw Model PWBS-14CS
I cant seem to find the blade size for an older pro tech bandsaw model 3101. Is there a newer model that is compatible?
There should be enough adjustment on the tensioner to allow you to use any size blade that will be close to the original size. Set the tensioner/adjuster to the mid position measure the size of the blade, and look for one close to that size.
Nov 10, 2014 | Saws
Shopcraft 10in. bandsaw model t676020p band legnth
Do you have the manual? It might be there but I think the blade length is about 65 inches. If you're looking for new band saw blades, you may try checking www.sawblade.com . I purchased mine with them . They have pretty good blades.
Feb 03, 2013 | Saws
Replacement parts for central machinery bandsaw, blade and belt
take a look on amazon: Amazon com bandsaw blade, Last time I bought same parts from there. cheers
Dec 31, 2011 | Saws
I have a used bandsaw but i don't know what model
Band saws are measured by length and width of the blade so measure the length or just take it to the parts place and you should be able to get one of the same size unless its an old or off size no longer made but I dont see that being a problem. Try ebay for your measurements or even Grainger.
http://business.shop.ebay.com/Metalworking-Tooling-/92084/i.html?_nkw=band+saw+blades&_catref=1&_fln=1&_trksid=p3286.c0.m282
May 13, 2011 | Delta Saws
I'm looking for replacement bandsaw blades for a McGraw-Edison 10" Bandsaw, M/N - T6760. Any Ideas?
I have 11[6 tooth scrolling blades] & 3[3/8" 14 tooth general purpose metal cutting blades.T8380-16 & T8382-16 for McGraw Edison 10" bandsaw. blades are 57" been hanging in my garage for past 25 yrs lol. would like to sell to best offer. contact me at tazzdh1959@yahoo.com
Feb 24, 2011 | Saws
Hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
Dec 08, 2009 | Craftsman Saws
Grizzly bandsaw cannot fit blade
I lowered the spacer (on the threaded rod) and got enough drop in the upper wheel to fit the blade.
Jan 11, 2009 | Saws
Saws Logo
917 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
